    Original Snes + NES + Sega Controller
    Controller/GPIO/USB
    original snes nes sega
    2585
    • Jura
      Jura last edited by
      Hallo zusammen.
      Ich möchte die Snes, NES und Sega Emulatoren mit den Originalen Controllern steuern.
      ( am Raspi3 ).
      Das ganze in einem Snes Gehäuse. Vorne Original Snes Controller und Hinten NES und Sega Mega Drive Controller.
      Jetzt meine Fragen:
      1. Kann man 2 Controller Treiber gleichzeitig installieren "DB9 und Gamecon"?
      2. Wie sollten dann die Pinnbelegungen aussehen. Es würden dann natürlich die nicht benutzten Controller ausgestöpselt sein, damit sie sich nicht überschneiden.
      Würde mich freuen wenn mir jemand diesbezüglich helfen könnte. Oder eventuell etwas änliches schon realisiert hat.
      (Manche wiki links sind down, was das Thema angeht 😞 )
        Substring @Jura last edited by
        @jura Hi !
        According to my understanding of your question ... I'm not sure DB9 and gamecon can be loaded together, this would all depend on the pins they use. And I do not have the necessary hardware to test it myself.
        • Jura
          Jura last edited by
          Ok.
          Is here maybe somewhere an detailed instruktion, how to get both Snes and NES Controllers on 1 System?
          (Original Snes Controller Board with 2 Player, inkl. the original Snes Power LED on the front + The Original NES Controller on the back on my Snes case.)
          Sorry for my very bad english.
            @jura Your english is fine, don't worry 🙂
            The very little i could find : https://github.com/recalbox/recalbox-os/wiki/Gamecon-controllers-(EN)
            the only dB9 wiki i found is retropie's and it still shows the schema of the Pi1 GPIO 😕 But some people here succeeded using either one either the other.
            • Jura
              Jura last edited by
              This post is deleted!
              • Jura
                Jura last edited by
                @Substring
                Thank you for yoir help.
                I will wait. Maybe any one who has successful realise my wish, want to tell me how.
                  @jura you'd be more lucky by searching through the forum I guess. I remember answering some topics on gamecon not too long ago, and i'm sure I already helped someone with modding a megadrive to make it work on Recalbox
