    Help needed with connecting xbox compatible gamepad
    GamePad/GPIO/USB encoder
    help needed connecting xbox gamepad
    • SirMunkyHead
      SirMunkyHead last edited by
      Instaled RecalBox 4.1.0 on Pi3
      connected my Defender Scorpion X7 to Pi3 and "Gamepad not Detected"
      dmesg says:
      [ 1438.993114] usb 1-1.4: New USB device found, idVendor=1345, idProduct=6006
      [ 1438.993123] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      [ 1438.993130] usb 1-1.4: Product: USB Controller
      [ 1438.993137] usb 1-1.4: Manufacturer:
      [ 1438.993143] usb 1-1.4: SerialNumber: CF9B9100
      on PC gamepad is defined as a "controller xbox 360 for windows"
      search in Google find next
      "sudo yum install xboxdrv
      sudo xboxdrv --device-by-path 001:005 --type xbox360 --silent
      xboxdrv 0.8.5 - http://pingus.seul.org/~grumbel/xboxdrv/
      Copyright © 2008-2011 Ingo Ruhnke grumbel@gmx.de
      Licensed under GNU GPL version 3 or later http://gnu.org/licenses/gpl.html
      This program comes with ABSOLUTELY NO WARRANTY.
      This is free software, and you are welcome to redistribute it under certain conditions; see the file COPYING for details.
      Controller: unknown
      Vendor/Product: 1345:6006
      USB Path: 001:005
      Controller Type: Xbox360
      Your Xbox/Xbox360 controller should now be available as:
      /dev/input/js0
      /dev/input/event14"
      How can I make it in recalbox?
        Substring @SirMunkyHead last edited by
        @sirmunkyhead Hi
        so, xboxdrv is not compatible with 4.4 kernel (and later). Looks rather like we may have to patch the kernel so that it understands that it should link the xpad driver to your pad.
