    Solved PC Engine CD 4.1 Stable problems
    Emulator Arcade/PC/Console
    engine 4.1 stable
    • Zeveronn
      Zeveronn last edited by
      good morning everyone
      Since the new update I try to run the games Pc Engine CD but impossible to launch anything.
      I tried a lot of techniques that can be found on the forum, especially the plug "to read" regarding the emulator pc engine cd but nothing does , I just have a return to the recalbox menu
      I can not launch Akumajou dracula X while on the 4.1 unstable, I did not have this problem
      would you have a solution? because I really do not know what to try.
      Thank you
        Substring @Zeveronn last edited by
        @zeveronn you need :
        • the pce cd bios (i don't remember the name)
        • a cue+bin cd image
        • the cue must exactly refer to the .bin, it is case sensitive.
        Usually i rename the .cue and .bin + edit the .cue to point to the right .bin
        Zeveronn 1 Reply Last reply Reply Quote 0
        • Zeveronn
          Zeveronn @Substring last edited by
          @substring thanks ! It was the bios, now it works
          I also change the .cue and .bin
            @zeveronn change it to resolved then 🙂
            • kelv
              kelv last edited by
              I'm having similar issues @Zeveronn but I have the bios right an the cue bin image too. Only Castlevana is working. I will try a new bios as said.
              Raspberry Pi model: RPi 3b+
              Recalbox build : 7.0.1 DragonBlaze
              Hardware: MicroSD UHS 128 GB up to 80 MB, Class 10 and 2.5 A Power Supply.
              Overclocked: 1485 MHZ
              Controller(s): Wired Xbox 360 PAD (working perfectly on any other game/emulator).
