    Crash Glupen64 core, fresh install
    n64 mario party crash issue glupen64
    2318
    • Alanna López
      Alanna López last edited by
      Hi :), so I write this because of an issue I'm getting with the glupen 64 core, I confirmed this core makes the mario party games work with no graphical issues, the problem is that the whole emulator crashes randomly when playing, from mere seconds to a couple of minutes... does anybody have the same issue?
      Is there anything I can do to help get this fixed? I believe it's not the core itself, because when it lasts longer everything works just fine, but it's crashing randomly, on other games as well, I don't mind the lower resolution it seems to use, but I'd love to finally play mario party 2 here...
      the rom I use is a Mario Party 2 (E) (!) with libretro ---> Glupen64, any other info I'd be happy to give (as long as I'm told how to get it)
        Substring @Alanna López last edited by
        @alanna-lópez hye
        Can you give all the required informations regarding your config please ? board, inputs blablabla ...
        Alanna López 1 Reply Last reply Reply Quote 0
        • Alanna López
          Alanna López @Substring last edited by
          @substring sure thing
          I use a raspberry Pi3 B with no modifications and an 8gb micro SD card.
          recalbox 4.1 with a fresh installation, Originally I updated from 4.0.2 but I blamed a bad upgrade to those crashes, so I installed again the whole thing.
          I used an 8bitdo nes30pro controller and a wired xbox 360 controller.
          I also followed the instructions in the github to have the games booting from USB.
          Under the retroarch menu I tested the 4 video drivers, it crashed with all of them.
          do you need anything else?
            @alanna-lópez I can't trust yet the core, nor do i have time for now to test by myself here
            @rockaddicted can you sched some light here ?
            • Soufian
              Soufian last edited by
              You find a fix for the crash?
                Hello
                please dont up old topic.
