    Unsolved slow, braking system
    slow braking
    6
    38
    15413
    • Edvis
      Edvis @Substring last edited by
      @substring
      @jeevuz said in slow, braking system:
      @Edvis Hi you use crt tv? I have the same problem onli in crt tv, hdmi works great.
        Substring @Edvis last edited by
        @edvis So you have problems since you're on CRT ? Well, @jeevuz hada great idea ! How are you connected ? Do you have "really many" roms ? where do the slowdowns happen ? Can you make a support archive by going to http://recalbox/help ?
        Edvis 2 Replies Last reply Reply Quote 1
        • Edvis
          @substring There is no difference how many Roms, on one sd card there are Roms, on the second sd card only standard roms. the problem is the same. the problem arises immediately at boot, the cross triangle and the square are rotated slowly and the sound is slow. slow sound in the menu and slow games. Yes I use crt tv.
          your link http://recalbox/help does not open
          • Edvis
            @substring
            slow in all Roms
              Guys if you are using an "exotic" setup you must tell us. Crt screen on composite is about 1% of users.
              Anyway, it is a good point to catched that.
              To be able to on this address your rpi must be connected on your local network.
              You can generate manually an archive support by ssh.
              Please look this wiki: https://github.com/recalbox/recalbox-os/wiki/Recalbox-support-(EN)
                @edvis you need to connect your Pi to the Network. If you're using a mac then try http://recalbox.local/help
                I have used a 4.1 on CRT using the composite cable, had absolutely no problem. So can you detail your full setup ?
                Edvis 1 Reply Last reply Reply Quote 1
                  I'm using too a 4.1 plugged on rca to my car screen to play mario kart while driving, and no issue. 😄
                    voljega Banned @rockaddicted last edited by
                    @rockaddicted except when you see a blue shell coming at you in the rear window 😄
                    • Edvis
                      @substring https://file.ac/PqcTAmt1ESU/
                        @edvis Could you comment audio_pwm_mode=2 in your config.txt and reboot ?
                        • Edvis
                          @substring I'm shocked, wow, everything worked, thank you very much.
                            @edvis i remember i had the problem with this parameter, but i also had some crap connected to the GPIO AFAIR. Should dig this further though, if we're not on a firmware bug or god knows what
                              Once we have all informations we can debug properly 😉
                              • Edvis
                                @substring clearly, thank you very much)))
                                • Edvis
                                  Edvis @jeevuz last edited by
                                  @jeevuz
                                  @substring said in slow, braking system:
                                  jeevuz 1 Reply Last reply Reply Quote 0
                                  • Edvis
                                    Edvis @rockaddicted last edited by
                                    @rockaddicted 😃
                                    • jeevuz
                                      jeevuz @Edvis last edited by
                                      #audio_pwm_mode=2 perfect!!!!!! it works like a charm thx.
                                      • vbu
                                        vbu last edited by
                                        Old thread, but for the few who still use composite output in recalbox 6.0, where audio_pwm_mode=2 doesn't exist anymore, now works fine with audio_pwm_mode=0. At least in my RPi3.
                                        100.6k
