    [Solved]Street Fighter on Megadrive
    [solved]street fighter megadrive
    3211
    • pangren
      pangren last edited by
      Hi Guys. Firstly, I love the project awesome work. Now everything works fine, but Street Fighter on Megadrive kind-of required 6-buttons , but only 3 are working (as with most Sega megadrive games ) Anyone managed to get Street Fighter 2 working properly or know how to configure my buttons for this game to work ?
        Hello pangren are you sure trigger R and Trigger L don't work in game ?
          Hello you need to tell retroarch to use 6 buttons controllers, because the default is to use 3 buttons ones. Launch a megadrive game and go in the retroarch menu (hotkey+B). Go in Settings > General Settings > Put Configuration Save On Exit -> ON Go in Options > Core Options and set the two input devices to 6 button pad HOTKEY+B to exit i Think it ok now.
          • pangren
            Hey thanks Acris, yes it worked! and all my other games all still worked well. I think it'd be good to set this as the megadrive default for the next update . Thanks yo.
              Hello i add into wiki https://github.com/digitalLumberjack/recalbox-os/wiki/6-buttons-for-megadrive-(EN)
              • pangren
                Cool thanks.
                • digitaLumberjack
                  If I set this option by default, does the controllers works with 3 buttons games ?
                  • pangren
                    Yeap 3 button games still work the same. I think you should just make it a default.
                    • digitaLumberjack
                      Ok i added an issue : https://github.com/digitalLumberjack/recalbox-os/issues/307
