    No more sound after installing v. 4.1 in recalbox
    MediaCenter & Dualboot
    more sound installing 4.1 recalbox
    10
    215
    115550
    • benj008
      benj008 last edited by
      Hi
      I ve just installed the 4.1 version of recalbox this morning and the sound doesn t work anymore...
      I don t understand because in v 4.0.1 everything worked perfectly.
      I ve a rpi 2 with an extra sound card plugged in jack.
      Kodi seems unable to load anymore from the recalbox menu too.
      What can i do to get the sound back please?
      Thanks
        Substring @benj008 last edited by
        @benj008 Hi
        Set the sound to jack in ES, and reboot
        benj008 1 Reply Last reply Reply Quote 0
        • benj008
          benj008 @Substring last edited by
          @substring thank you but still not working...
            @benj008 which sound devices are listed in ES beside auto/jack and hdmi ?
            • benj008
              @substring it s only hdmi jack and auto.
              I was in auto in version 4.0.1 for info.
              The device is a hifi berry dac+ standard RCA.
              Thanks
                @benj008 so it's not the standard jack dude, what are you telling me ? lol
                @lackyluuk any problem with 4.1 and your hifiberry ?
                • benj008
                  @substring in fact it s going out of the raspbery box in rca and plugged into the amp in jack i don t know if i m clear sorry.
                    @benj008 ok so, can you SSH to recalbox and run TERM=xterm alsamixer , make sure all volumes are set to 100%, and check all sound cards on F6 ?
                    • benj008
                      @substring it appears PCM in the bottom is at 100% and when i push f6 i m in default. Do you wish me to put the other option avaliable? It s bcm2835 alsa
                        @benj008 can you check the config.txt to make sure the overlay is there ?
                        • benj008
                          @substring how do i do this please?
                            @benj008 you know that you have to configure at least some system options to have the hifiberry working, don't you ?
                            • benj008
                              @substring tu parles pas francais par hasard??
                              je suis dessus et je regarde en meme temps d'autres topics
                                @benj008 oui oui
                                Donc : hifiberry, il faut editer /boot/config.txt
                                • benj008
                                  @substring j'ai fait, j'ai vu que l'overlay etait deja dedans qd je scroll vers le bas je l'avais fait dans ma config initiale je pense
                                  apres je fais la manip avec /etc/asound.conf et la j'ai ca
                                  pcm.!default {^M
                                  type hw card 0^M
                                  }^M
                                  ctl.!default {^M
                                  type hw card 0^M
                                  Les ^M c'est normal?
                                    @benj008 non, ca sent le fichier édité sous windows ca, pas beau. Tu as vu où cette manip ? aucune raison de la faire ...
                                    • benj008
                                      dans le forum paragraphe Device tree and config apres l'overlay
                                        @benj008 vire moi ce fichier pour commencer 😉
                                        • benj008
                                          tu fais comment? j'ai pas trop l'habitude sorry
                                            @benj008 ah ok
                                            mount -o remount, rw /
                                            rm /etc/asound.conf
                                            Ensuite tu rebootes et tu me dis
                                            100.7k
