    Odroid XU4 issues with 4.1 Stable
    odroid xu4 4.1 stable
    9
    32
    13322
      Substring @jkno23 last edited by
      @jkno23 I've talked with memeka, that's something i'll dig later, though i don't see any benefits yet. Could you tell me why GBM is better than FBDEV ?
      jkno23 1 Reply Last reply Reply Quote 0
        Substring @aze last edited by
        @aze yeah, the terminal is something complicated to handle with ARM GPUs ... Something to do with SDL I guess
        • jkno23
          jkno23 @Substring last edited by
          @substring According to memeka FBDEV is stable under 3.10 Kernel and after switching to official odroids 4.9 Kernel the FBDEV becomes buggy. The stable (according memeka) alternative under 4.9 Kernel is DRM/KMS + GBM.
            @jkno23 yeah, but crashoverride didn't look that convinced (look at the post i made in the GAMES AND EMULATORS subforum)
            but of course if it works at least the same, i'll probably switch to it. But not yet if you don't mind 🙂
            • grgohr
              grgohr @grgohr last edited by
              @grgohr said in Odroid XU4 issues with 4.1 Stable:
              I saw the following in the changelogs but I still need to force usbhid.quirks=0x16c0:0x05e1:0x040 in the boot.ini file, otherwise only player 1 is recognized for the Xinmo dual arcade
              • Add xin-mo 18pin, mayflash N64 and correction usbhid
              hello @Substring beside the xinmo dual arcade issue still being faced, it still does not work at all in Moonlight => is it possible to include the latest 2.4.3 version in the builds as it includes SDL controls instead of the 2.2.2 that is quite old now ? Might help to solve the issue ? (PPSSPP works well with it finally but no luck in Moonlight). Congrats for the stable version and good luck in managing the feedbacks !
                Substring @grgohr last edited by
                @grgohr Moonlight is the 2.3.0, the dev didn't b*mp the version number.
                Regarding XU4 and moonlight, it has no hw acceleration, so ... ahem ... looks bad ...
                Anyway, moonlight will be b*mped later because there have been some major changes in the pad configuration, need to rewrite the configgen.
                Regarding xinmo, shouldn't be too hard to solve, i have to check a few things here and there first
                  d**n what's wrong ???
                  # cat /sys/module/usbhid/parameters/quirks
                  (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
                  whereas it should be full ...
                  edit: ok found the problem, will work on it
                  • Jimmy Truffaut
                    Jimmy Truffaut last edited by Jimmy Truffaut
                    Hi everyone,
                    GlideN64mk2 works great with these parameters, thanks so much!
                    Did someone have found a concrete solution about the ScummVM issues (black screen and back menu) on ODROID XU4??
                    Thanks, have a nice day
                    You do great work!
                      Substring @Jimmy Truffaut last edited by Substring
                      @jimmy-truffaut yeah, found the solution : need to upgrade scummvm. If you are not patient, you need to recompile by yourself. @Cthulhus made it yesterday on pi and kinda detailled his steps (in french, sadly)
                      • MarcDK
                        MarcDK last edited by
                        @aze said in Odroid XU4 issues with 4.1 Stable:
                        force_polygon_offset = True
                        @aze Where do I put this? Which file and where is it?
                        https://marc.tv
                        quenbo 1 Reply Last reply Reply Quote 0
                        • quenbo
                          quenbo @MarcDK last edited by
                          @marcdk said in Odroid XU4 issues with 4.1 Stable:
                          You have to edit this file : /share/system/configs/mupen64/mupen64plus.cfg
                            rockaddicted @quenbo last edited by
                            @quenbo on last 17.12.02 you can also switch on gliden64 core
                            100.6k
