    Arduino Leonardo Controller run as a "joystick"
    GamePad/GPIO/USB encoder
    arduino leonardo run joystick
    4103
    • Gelbeseiten
      Gelbeseiten last edited by
      Hello,
      I am new and have only recently dealt with the Raspberrypi.
      I am very enthusiastic about the RecalboxOS package!
      Quickly installed and pretty much all the packages you need are there.
      Let's get to my problem.
      I would like to emolate the Arduino Leonardo Controller to run as a "joystick" like the "Arcade" machines.
      Has anyone there experiences with it?
      Would be great if he shared it with me!
      Thank you and have a nice day.
      Volkmar
      • ironic
        ironic last edited by ironic
        I did it. It works well with an Arduino (ATmega32u4, not an ATmega328 / 168).
        You can also use a Teensy.
        There are many sites to learn how to do this.
        I used this lib :
        https://github.com/MHeironimus/ArduinoJoystickLibrary
        and an Arduino Pro Micro ATmega32U4 5V /16MHz (clone).
        My goal is to use RGB leds inside buttons and illuminating this buttons with any colors i want.
        Buttons will light just before an emulator is launched.
        If this emulator use only 4 buttons, only 4 buttons will be illuminating like neogeo colors buttons.
        It works but no time to finish it.
        I used addressable RGB led
        (WS2812 and/or APA106).
        e.g.
        https://www.youtube.com/watch?v=3JKofBaJCe4
        Substring Gelbeseiten 2 Replies Last reply Reply Quote 0
          Substring @ironic last edited by
          @ironic said in Arduino Leonardo Controller run as a "joystick":
          rgbcommander ?
          • ironic
            No need rgbcommander.
            'All' is done by Arduino :
            • Joystick 'emulation' (no lag input, can emulate severals joysticks).
            • Keyboard 'emulation' (To add some key like 'Esc', 'F1'.... on joystick panel).
            • RGB leds driving. (24 bits Addressable LEDs are inside buttons and one in transparent joystick ball)
            There is a serial connection between Arduino and Rpi (USB cable).
            Arduino tell to Rpi, there is a joystick and a keyboard connected.
            Rpi send (python script before launchin emulator) serial commands to Arduino for selecting LEDs colors.
            All is working but i need a 3d printer to perfectly integrate my RGB LEDs in buttons...
            Can use a ESP8266 for wireless joystick.
            • Gelbeseiten
              Gelbeseiten @ironic last edited by
              @ironic
              THX a lot for your Info!
              I will try that out in the next days and I will let you know.
              Have a good one!
              Best
              • Gelbeseiten
                The illuminated Buttons are great!
                If my Project is ready, I will try that as well out!
