    Xbox 360 controller help
    xbox 360 help
    8547
    • rabbit1080
      rabbit1080 last edited by
      Ok, let me say this is my first experience with linux or raspberry pi. I have been a proud and frustrated owner of a raspberry pi 3 for about 5 weeks now. Everything seems very foreign to me, and it has been one problem after another. After repeated failures (roughly 12-15) with retropie, I abandoned it, and adopted recalbox. For the past 2 weeks, I have been trying to get a wireless controller to work, with absolutely no luck. I've been trying a wireless xbox 360, ps3, and a cheap bluetooth mini controller. None of them have worked. I have a pc wireless xbox 360 dongle and a bluetooth dongle, because the recalbox does not support the internal pi bluetooth radio (correct?). The only luck I've had is with a wired xbox 360 controller. I took a while, but I finally got the wired 360 controller to light up quadrant 1. The farthest I've got with a wireless xbox 360 controller is for the dongle to show its synced, the pi to recognize another gamepad (even though I cannot map any of the buttons) and the wireless 360 controller to flash all 4 quadrants of the light ring forever. What am I missing?
        Hi, did you read the manual and applied the sync method ?
        https://github.com/recalbox/recalbox-os/wiki/Manual-(EN)#ps3controllers
        https://github.com/recalbox/recalbox-os/wiki/Manual-(EN)#xboxcontrollers
        • rabbit1080
          Sure did. Doesnt help. That manual shows how to map the buttons. Which doesnt help because ring of light on the 360 controllers just keeps flashing, and doesnt allow me to map any buttons at all
            rockaddicted @rabbit1080 last edited by
            @rabbit1080 which recalbox version ? it is fixed since 4.1 release.
            rabbit1080 1 Reply Last reply Reply Quote 0
            • rabbit1080
              rabbit1080 @rockaddicted last edited by
              @rockaddicted Yeah, since the update this morning, it works flawlessly! Thanks a lot man, I appreciate it. This thing has been the bane of my existence the past few weeks
              • albertwesker
                albertwesker last edited by
                Hi Guys,
                i have the actual recalbox set up. i use a xbox 360 wired controller and it worked perfectly since the beginning.
                Unfortunately this is the only one i have but i want to get multiplayer working. Now today i asked my wife to buy an original xbox 360 wired controller 🙂 🙂 what i got is an afterglow wired controller with smart track and so on 😄 long story short it didnt work. Is it worth it to try to get it working or should i bring it back? It immediately syncs and so on but i cant navigate or anything. Any tips?
                  Substring @albertwesker last edited by
                  @albertwesker have you tried to configure it in ES ?
                  • albertwesker
                    @substring since i couldnt do anything no but i will try tomorrow with the other controller.. somehow 😄
                      @albertwesker could be a pad that requires a driver update. I wouldn't be surprised someone aleeady had your problem
                      100.8k
