    Problem identifying Recalbox partition
    identifying recalbox partition
    • Defiant
      Defiant last edited by
      Hi!
      I'm having trouble identifying the Recalbox partition so it'll boot directly into Recalbox instead of booting NOOBS first.
      I just want to get rid of the "press shift for Recovery" screen with the raspberry logo.
      I created the autoboot.txt file in my SD in Windows and wrote "boot_partition=6" in it as adviced in forums, but it had no effect.
      So, which is the partition I'm looking for?
      I tried every single one of them, from the logical ones to the extended ones, from 0 to 8, with no effect.
      What am I doing wrong?
      Here's a screenshot of my SD and partitions just in case.
      Thanks a lot in advance!
        Substring @Defiant last edited by
        @defiant is that a noobs option ? In which file have you added the boot_partition ?
        Defiant 1 Reply Last reply Reply Quote 0
        • Defiant
          Defiant @Substring last edited by
          @substring in autoboot.txt, I read that should do the trick. But it didn't.
            @defiant you dropped it on the very first partition ? Any official documentation on that feature ?
