    Ps1/ps2 controller
    GamePad/GPIO/USB encoder
    ps1ps2
    • bigderill
      bigderill last edited by
      Good evening, I wanted to know if it is possible to connect a control ps1 directly without USB interface (with gpio for example) http://i50.twenga.com/videojuegos/mando-psone/controller-ps1-dualshock-psone-tp_4445958922080149613vb.jpg Thanks
      • digitaLumberjack
        Hi, yes it's possible ! You will have to enable the gamecon GPIO in the https://github.com/digitalLumberjack/recalbox-os/wiki/recalbox.conf-(EN) and use the pinout at https://github.com/RetroPie/RetroPie-Setup/wiki/gamecon_gpio_rpi 🙂
        • bigderill
          Thanks Retroboy. one more question psx_sel which connector is ? http://2.bp.blogspot.com/-yzbRd2pdUb4/UOpyzTldczI/AAAAAAAAAF4/EmcrRnZ3w1k/s1600/PIN+KONFIGURASI.png 3.3v is 5 Pad (1,2,3 & 4) is 1 GND is 4 PSX_CMD is 2 PSX_CLK is 7 PSX_SEL is 6 (atenttion)???
          • digitaLumberjack
            I don't know. If you only have 3.3v you can test both safely.
            • bigderill
              Tonight if I take time proves it and comment. Thanks
