    Issue with PS3 controller, works un menu not in games
    GamePad/GPIO/USB encoder
    issue ps3
    2109
    • charlesmarried
      charlesmarried last edited by
      Hi Guys, what the title says. I bought a PS3 controller not sure if is official, but I do not know if it is. The case is that the program perfectly recognizes the recalbox but at the time of getting into games is little more than a paperweight, does not recognize it in any emulator.
      Any ideas? Attachment support:
      http://www19.zippyshare.com/v/oDhwsUUh/file.html
      Thank you!
        Substring @charlesmarried last edited by
        @charlesmarried Can't check your support file atm, but have you tried remapping the pad inside ES ?
        charlesmarried 1 Reply Last reply Reply Quote 0
        • charlesmarried
          charlesmarried @Substring last edited by
          @substring
          I configure the Controller with the wizard of the menú, It is What hoy say?
            @charlesmarried yup ! Press start > controllers options > configure a controller
            • charlesmarried
              @substring
              Yep, I configure the Controller on this way... Any other idea? Thanks
              • charlesmarried
                charlesmarried last edited by charlesmarried
                IT is supposed to be an original controller, isnt it?
                alt text
                101.4k
