    Solved Recalbox v4.0.2 on Pi 3 PC Engine CD games not working now.
    Emulator Arcade/PC/Console
    recalbox v4.0.2 engine now
    • Necrobot20XX
      Necrobot20XX last edited by
      I upgraded to the Pi 3 and now my PC E CD games won't work. I transferred all of the bios files and checked the .bin and .cue to make sure they were lower case. Everything was fine until I switched to the Pi 3. I checked all of my other emulators and they are fine, so I don't know what to do now.
        Substring @Necrobot20XX last edited by
        @necrobot20xx habe you simply copied files from one SD to another or had all as an external storage ?
        Necrobot20XX 1 Reply Last reply Reply Quote 0
        • Necrobot20XX
          Necrobot20XX @Substring last edited by
          @substring I actually just figured out the problem and came back to update. All of my files are on an external device. I checked every other system and things worked fine. The problem was with the syscard3 bios, I just downloaded a new one and it fixed it. I don't know why the other one quit working when it was fine before.
