    Solved Bluetooth controller syncs fine, but can't config?
    GamePad/GPIO/USB encoder
    bluetooth syncs fine cant config
    • LordBarker
      LordBarker last edited by
      As above.
      Using the controller config menu it finds my 8bitdo Snes Bluetooth pad fine, it just won't it be configured. Any ideas how to do this? Thanks. I'm using RGB-Pi custom image.
      Thanks
        paradadf Staff @LordBarker last edited by
        @lordbarker then ask directly the creator of that custom image. Your controller works perfectly fine on recalbox if you start it in the right modus (stated in the wiki).
        • kjbstar
          kjbstar last edited by kjbstar
          Creators of RGB Pi have the very bad idea of using only Alpha unstable versions of Recalbox to make their custom images. The problem may come from here.
          • LordBarker
            Got it to pair and can use it, but the settings are all a bit nuts! And it stops my wired pad from working. Spoke to the developer, will be fixed in the beta 🙂
