    Is there anyway to upgrade from v4.0.0 to v4.0.2
    anyway upgrade v4.0.0 v4.0.2
    • Eric Chin
      Eric Chin last edited by
      Hi guy,
      Just wanted to know that is there any way to update the recalbox version from v4.0.0 to v4.0.2?
      Or i have no choice to copy out all the roms from my existing SD card then replace it to the new recalbox v4.0.1 sd card?
        Hi, nope no more upgrade from 4.0.0 to 4.0.2 available.
        You needs to do a clean install from a 4.0.1, then upgrade on 4.0.2 (or directly do a clean 4.0.2 net install with official noobs_lite).
        Eric Chin 1 Reply Last reply Reply Quote 0
        • Eric Chin
          Eric Chin @rockaddicted last edited by
          @rockaddicted Hmm... OK & thanks for your prompt reply...
          • lackyluuk
            @Eric-Chin You can actually have a USB stick storing all your data. The OS and data is separated then. After you can do a clean install and just use your usb key there without setting up every ROM, Scrape again.
