    Solved Two identical controllers
    GamePad/GPIO/USB encoder
    identical
    • pdmes
      pdmes last edited by pdmes
      Hi all. I love recalbox and my Raspberry is working like a charm with 4.1 unstable. I’m impressed of your solid work. (I have tried other platforms and all them have buggy stuff like contollers not working, too much configuration, crashes, etc.)
      I’m using my Raspberry with an 8bitdo SFC30 controller and I wanted to know how it was going to behave if I buy and new one of the same model
      Will it recognize both as separate controllers and work with 2 players? Do I need to buy a different one in order to have two different identifiers for the controllers?
      Thank you very much for your help 😊
        paradadf Staff @pdmes last edited by
        @pdmes you won't have any problem with a second one of the same model.
        pdmes 1 Reply Last reply Reply Quote 0
        • pdmes
          pdmes @paradadf last edited by
          @paradadf thank you very much! 😉
