    Recalbox
    Your discoveries
    recalbox
    • Paulo Albuquerque
      Paulo Albuquerque last edited by
      Hi all, this is my first time with recalbox.
      I'm from Brazil and I have an old lcd tv and the image size didn't fit very well. I run it on full HD on menu screen but the screen footer where we have the buttons and descriptions didn't appear very well .
      I would like to know if there's any way to reduce the screen size like five percent, this way the screen resolution will fit perfectly.
      Tx
      • azvarel
        azvarel last edited by
        Make sure you have the function on your TV psize and set auto adjust
        Zodian Theme | #SNESProject
        • Paulo Albuquerque
          I changed the theme and now fits ok to screen
            paradadf Staff @Paulo Albuquerque last edited by
            @paulo-albuquerque which theme were you using? Which one are you using now?
