    2 Question ( recalbox 4.0 and Nintendo3DS )
    Your recalbox
    recalbox 4.0 nintendo3ds
    • quanghieuci
      quanghieuci last edited by
      i,
      The recalbox is working fine in almost TVs here. But there is one tv, actually my room's tv, that when I turn on the Pi3 the inicialization screen appears but when the recovery screen disappears there is no image from the recalbox. I know that this Tv doesnt work with high values of resolution ( in the xbox, I have to put on the low resolution to works on this tv ) but I dont know how to change the recalbox's resolution. I tried to change this:
      CEA 5 HDMI : 1920x1080 @ 60Hz 16:9, clock:74MHz interlaced
      CEA 4 HDMI : 1280x720 @ 60Hz 16:9, clock:74MHz progressive
      on the system config, but it wasnt effective.
      I read the recalbox's manual and found this:
      "You must connect the recalbox on a DVI screen but you have a black screen ?
      Just edit the config.txt file, and comment the line
      hdmi_drive=2
      with a # :
      #hdmi_drive=2
      On recalbox v4.0.0, /bootpartition is on read-only.
      So before editing your config.txt, you must mount your /boot partition with read-write rights.
      Go on root acces, then type this command : mount -o remount, rw /boot"
      But I didnt find this adress (/boot)!
      and the second question
      In which roms folder should I put the roms of the Nintendo 3DS?
      • lackyluuk
        lackyluuk Translator last edited by lackyluuk
        @quanghieuci Hi 🙂
        Since recalbox 4.0.0 the system is read only:
        https://github.com/recalbox/recalbox-os/wiki/Make-a-partition-writable-(EN)
        Here you will find some more information about getting root access:
        https://github.com/recalbox/recalbox-os/wiki/Root-access-on-terminal-(EN)
        You can try to get the preferred mode of your TV with the command: tvservice -m CEA
        https://github.com/recalbox/recalbox-os/wiki/Video-configuration-detailled-(EN)
        If something does not work, then just ask again 🙂
        Regarding your second question: Afaik there is no 3DS available at the moment.
