    Gameslist.xml reverting changes
    gameslist.xml editing tags
    • Matra
      Matra last edited by
      Hi All,
      Fairly knew to the recalbox but it's pretty intuitive and easy to get around. Though after a scrape I noticed some issues so I manually edited the gameslist file in notepad++ and manually placed images into the downloaded images file (for this example it was the SNES folder).
      There were no read/write issues when using notepad++ but when I restarted the console it had loaded the 'old' gameslist as if I hadn't edited it at all... but the picture changes were there...
      What could this be?? I just want to correct titles/descriptions now that I have fixed the images... [running v4.0.2 stable]
        emulationstation must be killed before working/editing gamelist.xml files.
        so go on ssh -> /etc/init.d/S31emulationstation stop once modification done, /etc/init.d/S31emulationstation start
        Matra 1 Reply Last reply Reply Quote 0
        • Matra
          Matra @rockaddicted last edited by
          @rockaddicted Awesome, I knew it would be something simple! Thanks, I'll give it a try later
