    Solved N64 4:3 always, no 16:9, why?
    Emulator Arcade/PC/Console
    always 169
    • charlesmarried
      charlesmarried last edited by
      Hi, I change the screen configuration for all the emulators to 16:9 and N64 appears in 4:3. I changed in advanced mode the screen configuration for N64 to 16:9 and it still appears in 4:3, anyone know why? Is N64 only in 4:3? All the others emulators appears in 16:9
      Thank you!
        paradadf Staff @charlesmarried last edited by
        @charlesmarried sometimes it helps to adjust the ratio of your tv 😉
        charlesmarried 1 Reply Last reply Reply Quote 0
        • charlesmarried
          charlesmarried @paradadf last edited by
          @paradadf
          Thank you so much!
