    Problem with Bluetooth Dongle
    bluetooth dongle
    4555
    • LuanBF
      LuanBF last edited by
      Hello guys,
      There was a problem with my Bluetooth controls.
      I have a dongle and I can configure the controls normally on the Bluez driver.
      However, when you restart the system, the configuration is lost. I have to set it all up again.
      Does anyone know what might be happening?
      Thanks.
        Hello @LuanBF
        gamepad ? manufactuer bluetooth dongle ? version recalbox ? raspberry pi 3 ?
        • LuanBF
          Hello acris
          Gamepad: PS3 chinese
          manufactuer bluetooth dongle: sorry, i dont know
          Recalbox 4.0.2
          Rpi 3
            You need dongle BT 4.0 for ps3 gamepad
            but chinese gamepad it's bad.
            https://github.com/recalbox/recalbox-os/wiki/PS3-controllers-drivers-(EN)
            • LuanBF
              This is weird.
              Everything works perfectly. The problem to be only in saving the settings while doing the reebot.
              Can someone tell me where the files are for me to try to save manually?
              • LuanBF
                Hey guys,
                I discovered the cause of the problem. For some reason my dongle does not start with the system.
                As I discovered this:
                1 - I pa**ed the controls, everything working here;
                2 - The system has been restarted, the controls do not work after that.
                3 - Entering by SSH and typing bluetoothctl and power on the controls come back to work.
                alt text
                I'm not a big connoisseur of these systems, I thought I'd make a simple script and put the power on command every time the system started.
                Is there another way for me to do this?
                • LuanBF
                  Very well guys,
                  I was able to solve my problem.
                  I feel happy because I do not have great knowledge of this area, only determination.
                  After finding the problem, quoted in the post above, I solved the problem by putting a command at boot:
                  Echo "power on" | Bluetoothctl
                  Every time you start the machine bluetooth devices start normally.
                  Sorry for my bad English and sorry for the posts in a row.
                  Problem solved.
                  Links that helped me:
                  https://wiki.archlinux.org/index.php/bluetooth
                  https://forum.recalbox.com/topic/3206/bt-controller-does-not-autoconnect
                  https://github.com/recalbox/recalbox-os/wiki/Add-your-own-startup-script-(EN)
                  https://raspberrypi.stackexchange.com/questions/44520/bluetooth-autoconnect-on-reboot-car-setup-with-scripts
                  100.8k
