    xbox one controller help
    GamePad/GPIO/USB encoder
    xbox help
    • Jfrai
      Jfrai last edited by
      I have an Xbox one controller that i have been using with recalbox along with a logitech usb controller. Everything has been fine. I recently bought a new xbox one controller. However whenever i plug the new one in, recalbox doesn't seem to locate the controller. If i have both plugged in it wont locate either one, but if i have just the old one plugged in it works just fine. New controller works just fine on my pc. Any thoughts?
        Substring @Jfrai last edited by
        @Jfrai hi
        Mentionning your recalbox vetsion would be very helpful as a start
        Jfrai 1 Reply Last reply Reply Quote 0
        • Jfrai
          Jfrai @Substring last edited by
          @Substring 4.0.1 i believe
            xbox one only usb in recalbox 4.0.1/4.0.2
            you need to upgrade or fresh install recalbox 4.1 unstable.
              Even on 4.1 Xbox one gamepads only works on USB.
              But Microsoft modifies the gamepad's firmware each time he products a new gamepad generation... Even on the same console...
              So new Xbox one gamepads aren't supported (even on USB) on 4.0.x recalbox version.
              On 4.1 I b*mped the driver, so your gamepads (new and old) should be supported on 4.1 (if Microsoft didn't release a new gamepad with a new firmware version...)
