    X-Arcade Dual Stick Button 8 for both Player 1 & 2 only sends any input on release
    GamePad/GPIO/USB encoder
    x-arcade dual stick button both
    10079
    • kimmykaroo
      kimmykaroo @Substring last edited by
      @Substring Alright, thank you.
      • kimmykaroo
        @Substring How is it coming along?
          Substring @kimmykaroo last edited by
          @kimmykaroo For now my PC is setup to build for Odroid C2, i can't build yet for Pi3. My work over the C2 should be over in the weekend, meanwhile i'll probably have our build build a recalbox version with the modified xarcade. You need to be patient, I won't have much time for Recalbox bedore Sunday
            @kimmykaroo So :http://www42.zippyshare.com/v/GbiBxNhB/file.html looks like it worked fine for me, evtest working as expected :
            # evtest
            No device specified, trying to scan all of /dev/input/event*
            Available devices:
            /dev/input/event0:	Logitech USB Receiver
            /dev/input/event1:	Logitech USB Receiver
            /dev/input/event2:	XGaming X-Arcade
            /dev/input/event3:	XGaming X-Arcade
            /dev/input/event4:	Xarcade-to-Gamepad Device 1
            /dev/input/event5:	Xarcade-to-Gamepad Device 2
            /dev/input/event6:	SNES-to-Keyboard Device
            Select the device event number [0-6]: 4
            Input driver version is 1.0.1
            Input device ID: bus 0x3 vendor 0x1 product 0x1 version 0x4
            Input device name: "Xarcade-to-Gamepad Device 1"
            Supported events:
              Event type 0 (EV_SYN)
              Event type 1 (EV_KEY)
                Event code 276 (BTN_EXTRA)
                Event code 304 (BTN_SOUTH)
                Event code 305 (BTN_EAST)
                Event code 307 (BTN_NORTH)
                Event code 308 (BTN_WEST)
                Event code 310 (BTN_TL)
                Event code 311 (BTN_TR)
                Event code 314 (BTN_SELECT)
                Event code 315 (BTN_START)
                Event code 316 (BTN_MODE)
              Event type 2 (EV_REL)
              Event type 3 (EV_ABS)
                Event code 0 (ABS_X)
                  Value      2
                  Min        0
                  Max        4
                Event code 1 (ABS_Y)
                  Value      2
                  Min        0
                  Max        4
            Properties:
            Testing ... (interrupt to exit)
            Event: time 1499585090.886264, type 1 (EV_KEY), code 314 (BTN_SELECT), value 1
            Event: time 1499585090.886264, -------------- SYN_REPORT ------------
            Event: time 1499585091.262290, type 1 (EV_KEY), code 314 (BTN_SELECT), value 0
            Event: time 1499585091.262290, -------------- SYN_REPORT ------------
            Event: time 1499585091.694345, type 1 (EV_KEY), code 314 (BTN_SELECT), value 1
            Event: time 1499585091.694345, -------------- SYN_REPORT ------------
            Event: time 1499585091.926374, type 1 (EV_KEY), code 314 (BTN_SELECT), value 0
            Event: time 1499585091.926374, -------------- SYN_REPORT ------------
            Event: time 1499585092.302426, type 1 (EV_KEY), code 276 (BTN_EXTRA), value 1
            Event: time 1499585092.302426, -------------- SYN_REPORT ------------
            Event: time 1499585092.614465, type 1 (EV_KEY), code 276 (BTN_EXTRA), value 0
            Event: time 1499585092.614465, -------------- SYN_REPORT ------------
            Event: time 1499585092.822493, type 1 (EV_KEY), code 276 (BTN_EXTRA), value 1
            Event: time 1499585092.822493, -------------- SYN_REPORT ------------
            Event: time 1499585092.990517, type 1 (EV_KEY), code 276 (BTN_EXTRA), value 0
            Event: time 1499585092.990517, -------------- SYN_REPORT ------------
            Event: time 1499585093.566594, type 1 (EV_KEY), code 304 (BTN_SOUTH), value 1
            Event: time 1499585093.566594, -------------- SYN_REPORT ------------
            Event: time 1499585093.750617, type 1 (EV_KEY), code 304 (BTN_SOUTH), value 0
            Event: time 1499585093.750617, -------------- SYN_REPORT ------------
            Event: time 1499585094.142676, type 1 (EV_KEY), code 305 (BTN_EAST), value 1
            Event: time 1499585094.142676, -------------- SYN_REPORT ------------
            Event: time 1499585094.286691, type 1 (EV_KEY), code 305 (BTN_EAST), value 0
            Event: time 1499585094.286691, -------------- SYN_REPORT ------------
            Event: time 1499585094.702746, type 1 (EV_KEY), code 311 (BTN_TR), value 1
            Event: time 1499585094.702746, -------------- SYN_REPORT ------------
            Event: time 1499585094.878767, type 1 (EV_KEY), code 311 (BTN_TR), value 0
            Event: time 1499585094.878767, -------------- SYN_REPORT ------------
            Event: time 1499585096.006924, type 1 (EV_KEY), code 308 (BTN_WEST), value 1
            Event: time 1499585096.006924, -------------- SYN_REPORT ------------
            Event: time 1499585096.134938, type 1 (EV_KEY), code 308 (BTN_WEST), value 0
            Event: time 1499585096.134938, -------------- SYN_REPORT ------------
            Event: time 1499585096.406971, type 1 (EV_KEY), code 307 (BTN_NORTH), value 1
            Event: time 1499585096.406971, -------------- SYN_REPORT ------------
            Event: time 1499585096.470979, type 1 (EV_KEY), code 307 (BTN_NORTH), value 0
            Event: time 1499585096.470979, -------------- SYN_REPORT ------------
            Event: time 1499585096.887066, type 1 (EV_KEY), code 310 (BTN_TL), value 1
            Event: time 1499585096.887066, -------------- SYN_REPORT ------------
            Event: time 1499585096.935042, type 1 (EV_KEY), code 310 (BTN_TL), value 0
            Event: time 1499585096.935042, -------------- SYN_REPORT ------------
            Event: time 1499585099.391380, type 1 (EV_KEY), code 315 (BTN_START), value 1
            Event: time 1499585099.391380, -------------- SYN_REPORT ------------
            Event: time 1499585099.799422, type 1 (EV_KEY), code 315 (BTN_START), value 0
            Event: time 1499585099.799422, -------------- SYN_REPORT ------------
            Event: time 1499585102.799845, type 1 (EV_KEY), code 316 (BTN_MODE), value 1
            Event: time 1499585102.799845, -------------- SYN_REPORT ------------
            Event: time 1499585103.367901, type 1 (EV_KEY), code 316 (BTN_MODE), value 0
            Event: time 1499585103.367901, -------------- SYN_REPORT ------------
            Event: time 1499585103.655939, type 1 (EV_KEY), code 316 (BTN_MODE), value 1
            Event: time 1499585103.655939, -------------- SYN_REPORT ------------
            Event: time 1499585105.056126, type 1 (EV_KEY), code 316 (BTN_MODE), value 0
            Event: time 1499585105.056126, -------------- SYN_REPORT ------------
            So, download the file, use SSH to mount -o remount, rw /, copy the file to /usr/bin (use WinSCP if you're not familiar with linux command line), make sure atrtibutes have "executable" for the owner (with putty : chmod u+x /usr/bin/xarcade2jstick), reboot and voilà
            • kimmykaroo
              @substring It works! Thank you so much
