    Mega Drive six button usb issue
    GamePad/GPIO/USB encoder
    mega six button usb issue
    • WSP77
      WSP77 last edited by
      Hi, everyone! I am with a issue I could not solve by myself. I bought a mega drive/genesis style usb joypad, six buttons layout (without mode). Ok, when I configure the inputs via emulation station, there are not a free button for "select" neither for "hotkey". I just press down on keyboard and let these keys without configuration. BUT, when in game, the button B opens the emulator menu, like it was a combo "hotkey + x (B)". Anyone knows a way to correct this?
        Hummm can't do miracles, those gamepads aren't adapted in this usage.
        You can use it on player 2 (only player 1 can use hotkey's based features) or sacrifice a button to map hotkey.
        You could use a custom mapping without hotkey, but you'll have anymore way to quit easily the game.
        • WSP77
          Yep, you're right... If there where a way to configure hotkey and select buttons on keyboard...
            voljega Banned @WSP77 last edited by
            @WSP77 did you try to exit with esc on the keyboard ? It works on some emulators but not all of them maybe ...
            rockaddicted 1 Reply Last reply Reply Quote 1
              rockaddicted @voljega last edited by
              @voljega said in Mega Drive six button usb issue:
              hummm if there is no hotkey button defined on the gamepad, each button will send the "shortcut action" affected (start = exit, a reset etc...).
              So he won't be able to use a standard automatic config, and will need to use a custom config.
              Look at this wiki : https://github.com/recalbox/recalbox-os/wiki/How-to-use-custom-config-for-emulators-(EN)
              Search on forum to, other users may have had this kind of issue too with those controllers.
