    Problema con X-arcade 2players
    Mandos/GPIO/Codificador USB
    problema con x-arcade 2players
    9775
    • azo
      azo @Substring last edited by
      @Substring I have not been able to play with the x-arcade yet, recalbox detects x-arcade as keyboard not as two controllers.
      I could do something wrong.
      I think I need more easy and more detailed steps please.
      Thank you very much for your patience and help me
      My x-arcade is V1 and I connect it with the official cable to usb
        Substring @azo last edited by
        @azo ok V1 xarcade seem not to work, indeed. I'd need to dig a little more. Can you make a support archive ? Even, they are PS2 only, this would be quite dependant on the usb key you.d use to connect the xarcade. But there is an upgrade module to get native usb (56€ in France)
        • azo
          azo last edited by
          @substring said in Problema con X-arcade 2players:
          I did it before.I upload the archive at dropbox. You can find it here " https://www.dropbox.com/s/z1wo8fbq77r62jv/recalbox-support-20170627192008.tar.gz?dl=0 "
          do you need another one?
          I connect the x-arcade with the official adapter to usb. I have the original usb(pc) x-adapter and the playstation 2 x-adapter too.
          If doesn´t work with recalbox i will use another control-pad to play with rasp3 because i think that 56€ is expensive only for use with recalbox.
          The x-arcade works fine with another emulators on my pc.
          Thank you for your help 🙂
            @azo Yeah ok, foudn the problem ...
            Either you wait for a recalbox update that I add your device (i can't say i'm in a hurry for this now), either you follow the wiki https://github.com/recalbox/recalbox-os/wiki/Keyboard-encoder-configuration-(EN)#adding-your-own-keyboard-encoder. The devices you should test are :
            /dev/input/by-id/usb-Xgaming_X-Arcade-if01-event-kbd
            /dev/input/by-id/usb-Xgaming_X-Arcade-event-kbd
            azo 1 Reply Last reply Reply Quote 0
            • azo
              Great!! it works!!!!
              thank you so much for your help and patience
                @azo May I ask you a link to the device you used to convert your PS2 to USB ?
                • azo
                  @substring
                  I use the original X-arcade´s "X-adapter System USB Adapter".I don´t find it in the x-arcade web,is old.Remember my x-arcade is v.1
                  I can find this picture only
                  https://goo.gl/images/Bz5H6s
                  100.6k
