    Solved Help to install screen (linux command)
    help linux
    • yan74s
      yan74s last edited by
      Hello
      I try to install a TFT Screen SPI with this tutorial
      https://github.com/recalbox/recalbox-os/wiki/TFT-Screen-SPI-Bus-(EN)
      But I'm stuck because I can't install FBCP....
      I have to copy the FBCP file in the "/usr/bin" directory.
      But because I'm a a beginner with linux I tried the easy way for me :
      Get the file with my computer, and paste It into an USB stick
      then copy the file from an USB stick into the raspberry with the command line :
      cp -rv /media/usb0/fbcp /usr/bin
      But I have the error
      cp: can't create '/usr/bin/fbcp': Read-only file system
      My first question is : How can I change the read-only permission for /usr/bin ? to write into It ?
      My second question is : Am I on the right way ?
      Thanks for your help !
        paradadf Staff last edited by
        https://github.com/recalbox/recalbox-os/wiki/Make-a-partition-writable-(EN)
        After making the partition writable, you could use WinSCP to transfer it from your computer to your sd card. But you can go that way as well.
        • yan74s
          Thanks very much Paradadf !!!
          It works !!
          and thanks for WinScp, I didn't know It... I'll win so many time now !!
