    Solved Can't setup Recalbox
    cant setup recalbox
    2110
    • tonda2
      tonda2 last edited by
      Hello,
      I downloaded Recalbox 4.0.0 and put it on my sdcard. Then when I turned on my RPi zero, it showed me this screen.
      I can't click on anything. Does anyone know what should I do? Thanks!
      • DAM
        DAM last edited by DAM
        @tonda2 Hi, try to format the sdcard on sdformat in fat32
        Download the last version 4.0.1 https://github.com/recalbox/recalbox-os/releases/tag/4.0.1
        unzip and copy all to sdcard . On RPI try to plug a mouse to click in install.
        • abunille
          abunille @tonda2 last edited by
          @tonda2
          Do you mean the Pi Zero W?
          When yes:
          I mean the Zero W is not officially supported on 4.0.0, 4.0.1 or 4.0.2.
          You can follow the blog to know when it will be supported:
          https://www.recalbox.com/blog/en/.
          tonda2 1 Reply Last reply Reply Quote 0
            There are a few guides here in the forum on how to manually setup a Pi0-w with recalbox.
            It will be officially supported with the release of 4.1 stable.
            • tonda2
              tonda2 @abunille last edited by
              @abunille I've been using the Pi Zero W so I tried it with Pi Zero and now it works perfectly well. Tnak you so much!
              • abunille
                @tonda2
                Then have fun with playing 😉
                And how @Substring said, with release of 4.1 stable the zero W will be supported officially.
                Always have a look to the "blog"
                greetings
