    Twin Ps2 USB Adapter Problem with PS1 games
    Emulator Arcade/PC/Console
    twin ps2 usb adapter ps1
    4649
    • Raphael Bueno Hatencia
      Raphael Bueno Hatencia last edited by
      Hi, i have this adapter with 2 original ps2 controllers: 0_1496502151117_adaptor-product.jpg
      It works fine, all buttons in all emulators, including moonlight playing with another 2 ps3 controllers. Using 4.1 recalbox.
      But I have a problem playing PS1 games, when using this adapter, no command input is detected, many games won´t even pass by the start screen. (I´ve tried games like Marvel vs Capcom, B****y Roar I -II)
      I can even use hotkey + B to enter retroarch menu and everything is working fine.
      Can someone help me please?
        Hello
        please add support archive : https://github.com/recalbox/recalbox-os/wiki/Recalbox-support-(EN) or via http://recalbox
        Raphael Bueno Hatencia 2 Replies Last reply Reply Quote 0
          Raphael Bueno Hatencia @acris last edited by
          @acris Thx Acris. I´ve tried using /recalbox/scripts/recalbox-support.sh
          and via manager, but both give a message like "no space left". I have only 40% of the SD card filled. I think that support scrip have a bug, I already talked to Substring in the 4.1 bugs, but no solution yet.
          Back into the controllers problem, i´ve realized even my ps3 controllers inputs won´t work anymore on those games (PS1), but only one worked with ps3 and ps2 controllers, Crash Bash. There is something to do with multitap option or something?
            @acris Wait! after some tries, it worked via manager! https://file.ac/7lSl4HsOewI/
              Hello
              all files are empty
              very strange...
              Raphael Bueno Hatencia 1 Reply Last reply Reply Quote 0
                @acris I don´t know why but that script never worked on my pi3.
                In the beggining it was creating 4gb files, with the message "no space left", even with a lot of space free.
                I was testing the controllers config at rgui menu, there is Default, Standard and some others options. Whats the difference between these two?
                I´ve managed to make everything working again by changing that, exiting game and entering again. but the crash bash stopped working, but the others works again. Maybe I just need to change these when I need to play.
                  Hi, in psx emulator you can set your gamepad on normal/analog mod (retoarch menu - quick menu - options). Some games works only in normal mod, other in analog mod and others both.
                  Your gamepads have too a physical switch on normal/analog mod, and the mapping in es is not the same in these 2 mods.
                  So I'm pretty sure that is an issue betweens these mods gamepads + core. Last time I tried this adapter I had this kind of issue too.
                  I let you play with the different mods/options, and give us a feedback.
                    Raphael Bueno Hatencia @rockaddicted last edited by
                    @rockaddicted Yes both my PS2 controllers have that analog button, but the controllers dosen´t work without it.
                    I´ve done a little research and discovered that even with original ps1, some games won´t work with multitap ON.
                    There is 2 not so pratical solutions:
                    1- Let Multitap option always on AUTO. And controllers on Default.
                    This will work in most games up to 2 players.
                    When playing games with 4 players, change the controllers to Standard.
                    (remember to exit game for the changes do effect)
                    2- Use configuration per game. But I don´t like to have this ON, because it will create configs for all games you play. Well this is usefull, but things can get messy really fast.
                    I wanted to know the difference between controller on standard and default, by the word seem to be the same thing. Or if it is a way to leave it on automatic or something.
