    Moonlight freezes after a few seconds
    blackscreen sound moonlight streaming
    18168
    • Anon
      Anon @Substring last edited by
      @Substring Mh, I will try some things then. What do you mean with "Woumd need to manually launch moonlight"?
        Substring @Anon last edited by
        @Anon I need you to start moonlight the way recalbox does it so that we can check the output of moonlight.
        Anon 2 Replies Last reply Reply Quote 0
        • Anon
          @Substring Hey, not quite sure what you mean. Mind explaining?
          What I did now was editing the Moonlight conf, set a bitrate of 50000 and set the platform to "pi", sops to false.
          I installed the newest drivers from a few days ago and installed GFE 3.1.2.31, cleaned everything and paired with still the same result.
          The only error output when launching is:
          Failed to initialize libcec interface
          The rest is just a mass spam of:
          Returning RTP packet queued for too long
          Network dropped middle of a frame
          Returning RTP packet after queue overgrowth
          Network dropped end of a frame
          Waiting for IDR frame
          IDR frame request sent
          It's still just the recalbox footer in a black screen with sound.
          • Anon
            @Substring Some more research:
            [ 188.20] : HOME=/recalbox/share/system LC_ALL="de_DE.UTF-8" SDL_VIDEO_GL_DRIVER=/usr/lib/libGLESv2.so SDL_NOMOUSE=1 /usr/bin/emulationstation; [ -f /tmp/shutdown.please ] && (shutdown -h now);[ -f /tmp/reboot.please ] && (shutdown -r now)
            ['/usr/bin/moonlight', 'stream', '-config', '/recalbox/share/system/configs/moonlight/moonlight.conf', '-mapping', '/recalbox/share/system/configs/moonlight/mappingP3.conf', '-input', '/dev/input/event2', '-mapping', '/recalbox/share/system/configs/moonlight/mappingP2.conf', '-input', '/dev/input/event1', '-mapping', '/recalbox/share/system/configs/moonlight/mappingP1.conf', '-input', '/dev/input/event0', '-app', 'Dolphin']
            ---- recalbox-config.sh ----
              @Anon Please make a support archive https://github.com/recalbox/recalbox-os/wiki/Recalbox-support-(EN) and upload it somewhere so that i can check some logs
              Anon 1 Reply Last reply Reply Quote 0
              • Anon
                @Substring Thx! http://www75.zippyshare.com/v/OfFpGfAB/file.html
                  @Anon Sorry for the late reply ...
                  Does this happen only with Dolphin ? You'd better try wihth some supported Steam games first.
                  Anyway, what I was looking for is the command : '/usr/bin/moonlight stream -config /recalbox/share/system/configs/moonlight/moonlight.conf -mapping /recalbox/share/system/configs/moonlight/mappingP3.conf -input /dev/input/event2 -mapping /recalbox/share/system/configs/moonlight/mappingP2.conf -input /dev/input/event1 -mapping /recalbox/share/system/configs/moonlight/mappingP1.conf -input /dev/input/event0 -app 'Call of Duty: Advanced Warfare Multiplayer' : launch it, and give me its output
                  I'd also need the output of /recalbox/scripts/moonlight/Moonlight.sh list
                  • Anon
                    @Substring
                    Moonlight Embedded 2.2.2 (EMBEDDED;CEC;PI)
                    Too many options: No such file or directory
                    Searching for server...
                    Connect to 192.168.178.21...
                    NVIDIA GeForce GTX 770, GFE 3.1.2.31 (protocol version 7)
                    1. Dolphin
                    2. Cemu
                    3. Orcs Must Die! 2
                    4. DOTA 2
                    5. Saints Row IV (DX 11)
                    6. Tom Clancy's Rainbow Six Siege
                    7. Counter Strike: Global Offensive
                    8. PAYDAY 2
                    9. Diablo III
                    10. The Elder Scrolls V: Skyrim
                    11. Grand Theft Auto V
                    12. Steam
                    13. 战舰世界
                    14. Watch_Dogs 2
                    15. Paragon
                    16. Team Fortress 2
                    17. Minecraft
                    18. Call of Duty: Advanced Warfare Multiplayer
                    19. Overwatch
                    20. Heroes of the Storm
                    21. Warframe
                    22. Diablo III
                    23. Arma 3
                    24. Ghost Recon® Wildlands
                    25. Overwatch
                    26. Call of Duty: Advanced Warfare
                    Add input /dev/input/event2 (mapping /recalbox/share/system/configs/moonlight/mappingP3.conf)...
                    Add input /dev/input/event1 (mapping /recalbox/share/system/configs/moonlight/mappingP2.conf)...
                    Add input /dev/input/event0 (mapping /recalbox/share/system/configs/moonlight/mappingP1.conf)...
                    libcec.so.3: cannot open shared object file: No such file or directory
                    Stream 1920 x 1080, 60 fps, 50000 kbps
                    Initializing platform...done
                    Resolving host name...done
                    Starting RTSP handshake...done
                    Initializing control stream...done
                    Initializing video stream...done
                    Initializing audio stream...done
                    Initializing input stream...done
                    Starting control stream...done
                    Starting video stream...done
                    Starting audio stream...done
                    Starting input stream...done
                    Just a black screen with recalbox footer.
                      Are you running this over LAN or WiFi ? (don't use wifi ...)
                      Do you have moonlight on your phone ? does the same problem happen ?
                      • Anon
                        @Substring It's wired. Phone works fine.. didn't think about that lol. So it must be the Pi...
