    Change date format in ES game info
    date format
    2771
    • Alexander
      Alexander last edited by
      Hi,
      I would like to change date formtat in the field "Released" in ES game info
      Currently is mm/dd/yyyy, and I would like to change it to dd/mm/yyyy
      I haven't seen any option for that, so I assume that I have to edit some config file, do you know what file do I have to edit?
      Thanks
      • screech
        screech last edited by
        Not sure, and I don't want to say bulls**t, but isn't it "language" dependant ?
        • Alexander
          No, I have tried and it is not language dependant.
          I guess it would have to be in the file where the structure
          Rating
          Released
          Developer
          is stored
          • Alexander
            Anyone knows in which file is that structure stored?
            Thanks
            • godhunter74
              godhunter74 last edited by
              In gamelist.xml each rom folder have one.
              Maybe with a regex in notepad ++
              One by one can be a lot of work...
              Relier un écran I2C et afficher des informations sur les roms
              • Alexander
                In gamelist.xml the date format is yyyymmddThhmmss, and in ES game info the format is mmddyyyy
                So the date info from gamelist.xml is processed somewhere and it is shown in ES in another format (mmddyyyy)
                The template for ES game info has to be somewhere, I guess it is just changing the date format in the template, but first I need to know in which file is that template located
                Thanks
                • Piti
                  Piti last edited by Piti
                  I have nothing found in the files to change the format.
                  I would change it to dd.mm.yy when i found it.
                  101.4k
