    [WIP] * iDEA * A new variation of the simplelight theme
    Themes & Interface
    [wip] idea variation simplelight theme
    5204
    • fagnerpc
      fagnerpc Theme moderator last edited by
      Hey guys,
      I've been working on a variation of the simplelight theme that i called iDEA.
      The basis of iDEA was made a 'franchise selection' - instead of systems.
      Here's the actual theme on my RPi3:
      Full size screenshots:
      http://imgur.com/a/Ykzgq
      Well, im a noobie on themes... so i dunno how to save on svg format - instead i saved the logos on png format (which is preatty heavy). I used 720p resolution for the backgrounds and custom ogg sounds, anyway...
      ARCADE ALEKFULL
        Substring @fagnerpc last edited by
        @fagnerpc Despite being very cute, this theme will go against a rule that can't be avoided : you can't mix roms from different systems, because Recalbox won't know how to launch them.
        tikiandskull 1 Reply Last reply Reply Quote 0
        • tikiandskull
          tikiandskull @Substring last edited by
          @Substring But it can work if, in its directories, it uses only an emulator as source (by duplicating for example the directory Mame for base and by putting in it only street figther games for Mame) ???
          • Nachtgarm
            Nachtgarm last edited by
            Well... with a little bit of work, it could work like this
            Example for a Zelda Collection
            es_systems.cfg
            <system>
                    <fullname>ZC</fullname>
                    <name>snes</name>
                    <path>/recalbox/share/roms/zc/</path>
                    <extension>.smc .sfc .SMC .SFC .zip .ZIP .mgd .MGD .n64 .N64 .z64 .Z64 .v64 .V64 .gb .GB .gbc .GBC .gba .GBA</extension>
                    <command>python /usr/lib/python2.7/site-packages/configgen/emulatorlauncher.pyc %CONTROLLERSCONFIG% -system %SYSTEM% -rom %ROM% -emulator %EMULATOR% -core %CORE%</command>
                    <platform>snes</platform>
                    <theme>zelda</theme>
            	<emulators>
            	    <emulator name="libretro">
            	        <cores>
            		    <core>catsfc</core>
            		    <core>pocketsnes</core>
            		    <core>snes9x_next</core>
            		    <core>gpsp</core>
            		    <core>mgba</core>
            		    <core>meteor</core>
            		    <core>gambatte</core>
            		    <core>tgbdual</core>
                                <core>fceumm</core>
            		    <core>fceunext</core>
            		    <core>nestopia</core>
            		    <core>quicknes</core>
            		</cores>
            	    </emulator>
            		<emulator name="mupen64plus">
            	        <cores>
            		    <core>gliden64</core>
            		    <core>n64</core>
            		    <core>rice</core>
            		</cores>
            	    </emulator>
            	</emulators>
                </system>
              Substring @Nachtgarm last edited by
              @Nachtgarm Then you must set the emulator + core for each rom ...
              • Nachtgarm
                It's actually working like this. I tried it 🙂
                Substring fagnerpc 2 Replies Last reply Reply Quote 0
                  Substring @Nachtgarm last edited by Substring
                  @Nachtgarm I do believe you ! It's just a pain to configure 😉 + any update would kill the es_systems.cfg
                  • Nachtgarm
                    True. Updates would kill all of that 😉
                    • fagnerpc
                      fagnerpc Theme moderator @Nachtgarm last edited by
                      @Nachtgarm Yep, its functional in this way 😉
                      A little pain to set... but if you use the main emulator as source (the plataform which has the majority of the games) the process will not take that long.
                      The Street Fight 'series' for example:
                      The M.A.M.E. is the main platform - i just added the FBA LibRetro (for CPS3 games) and PSX (for some Vs games).
                      ARCADE ALEKFULL
