    Moonlight won't launch games
    Emulator Arcade/PC/Console
    moonlight wont launch
    14929
    • DJAndrom3da
      DJAndrom3da last edited by DJAndrom3da
      I just moved to a new place and after I got my internet hooked back up and connected both my PC and Recalbox to it I tried to launch a game on Moonlight but I got kicked back to the menu. I tried re-pairing my Recalbox with my PC but the same thing keeps happening. What should I do?
        Substring @DJAndrom3da last edited by
        @DJAndrom3da On the PC side, clear the paired devices.
        On the pi side, run the Moonlight.sh with the clean parameter, then rerun the usual pairing process
        DJAndrom3da 1 Reply Last reply Reply Quote 0
        • DJAndrom3da
          DJAndrom3da @Substring last edited by
          @Substring Thanks for the suggestion, but it still boots me back to the menu when I select a game
            @DJAndrom3da have you at least tried ? have you redone the full process ? (clean, pair then init)
            • DJAndrom3da
              @Substring Yes, I did
                Substring @DJAndrom3da last edited by Substring
                @DJAndrom3da as well as on GFE ? Which GFE version do you have ?
                • DJAndrom3da
                  @Substring 3.5.0.76
                    @DJAndrom3da have you changed your pads since ?
                    • DJAndrom3da
                      DJAndrom3da @Substring last edited by DJAndrom3da
                      @Substring What do you mean by "pads"?
                        @DJAndrom3da pads, controllers
                        • DJAndrom3da
                          @Substring Thought so. No I haven't changed them.
                            @DJAndrom3da Have you forced the IP adress in the moonlight.conf ?
                            • DJAndrom3da
                              @Substring Yes
                                @DJAndrom3da maybe your PC's IP changed ?
                                • DJAndrom3da
                                  @Substring the IPv4 address is still the same
                                    @DJAndrom3da It can fail for only 2 reasons :
                                    • configgen crashed
                                    • moonlight doesn't start
                                    Which recalbox version are you running ? 4.0.2 is not compatible with latest GFE versions
                                    • DJAndrom3da
                                      @Substring said in Moonlight won't launch games:
                                      @Substring That should do it, I am on 4.0.2.
                                      DJAndrom3da Substring 2 Replies Last reply Reply Quote 0
                                      • DJAndrom3da
                                        DJAndrom3da @DJAndrom3da last edited by
                                        @Substring so since there's no way of downgrading I'm basically out of luck until a future update that adds compatibility?
                                          @DJAndrom3da Then downgrade GFE
                                          • DJAndrom3da
                                            @Substring Alright I downgraded GFE to 3.0.5.22 but now when I try to pair it with recalbox it hangs on "Searching for server"
