    Wifi Problems
    wifi
    • ilikePi
      ilikePi last edited by
      Hello, I have been trying for the past hour to make my raspberry pi connect to the internet, however it simply refuses to connect. I have a raspberry pi 3 model B with this WiFi adapter: https://pishop.nz/RPI-WIFI-1/
      The WiFi network is 802.11g and the distance is approximately 10m . I have tried every conceivable variation of hostname, ssid and network key, and I am at my wits end! I cannot enter and IP address, and my recalbox version is 4.0.2, if that helps.
      • ilikePi
        b*mp, could someone please answer, I downloaded recalbox itself through the wifi, so its not a wifi problem, and I cant manually connect
          paradadf Staff last edited by paradadf
          Why are you trying to use a wifi adapter with a rpi3? Because of the g?
          If so, you need to blacklist the integrated wifi module following the wiki:
          https://github.com/recalbox/recalbox-os/wiki/Blacklist-rpi3-wifi-module-(EN)
