    CEC OSD name
    Your discoveries
    cec osd name
    5491
    • godhunter74
      godhunter74 last edited by
      I found this on retropie forum, you must try it, my TV doesn't support cec osd...
      If you connect your pi + RetroPie via HDMI, currently it appears as "raspberry" in the device list. A bit boring... but we can change that!
      In /boot/config.txt, add the line
      cec_osd_name=RetroPie
      Reboot, and now it appears as "RetroPie" 🙂 Note: on my TV I had to press a button to 'refresh' the AV channel list, to get it to update.
      So, this seems like something that could be automatic, so I was thinking about submitting it to the script, but not sure if it's a good idea and/or where to put it. Probably somewhere in https://github.com/RetroPie/RetroPie-Setup/tree/master/scriptmodules/supplementary ?
      Relier un écran I2C et afficher des informations sur les roms
        Substring @godhunter74 last edited by
        @godhunter74 wow wow wow ... I'll test and report. But I do like this feature, i was looking for it for some time but gave up.
        But please note : it's in /boot/config.txt, so no need of any script. It will be called Recalbox and that's all 😛
        • godhunter74
          Quelqu'un a t'il tenté???
            @godhunter74 oui, aucun effet chez moi
            • godhunter74
              C'est dommage 🙁
              D'autres équipements chez toi t'affichent leur petits noms sur ton écran ?
                Tested this morning and works pretty well for me.
                recalbox_cec
                  Ben ma TV ne doit pas gérer le CEC hahaha
                  • PoP's
                    PoP's last edited by
                    Cette fonction ne doit pas ĂȘtre disponible sur toutes les tv,
                    Ma Philips 42PFL3605H/12 Ă  bien le "EasyLink (HDMI-CEC) ",
                    elle démarre bien quand je démarre ma Recalbox, ma freebox ou autre, mais c'est à moi de nomme mes entrées manuellement.
                    D'ailleurs Ă  ce propos, je suis sur un dualboot Libreelec / Recalbox,
                    ma tv s'Ă©teint en mĂȘme temps que Libreelec, mais je doit l'arrĂȘter manuellement sous Recalbox,
                    J'imagine que Libreelec envoie un signal que Recalbox n'envoie pas?
                      Substring @PoP's last edited by Substring
                      @PoP's je doute que ce soit du code au niveau de libreelec ou de recalbox, mais plutĂŽt la configuration du /boot/config.txt. Mais j'avoue ne pas conanitre grand chose au CEC des pi
                      edit : j'aurais du fermer ma bouche ... les exemples que je lis sont basés sur libcec, qu'on a sur recalbox
                      PoP's 1 Reply Last reply Reply Quote 0
                      • PoP's
                        PoP's @Substring last edited by
                        @Substring
                        J'y connais pas grand chose, mais ça m’intĂ©resserais de chercher ça quand j'aurais un peu de temps
                          @PoP's ben regarde comment marche cec-client 😉
                          • godhunter74
                            Ce site est sympa
                            texte du lien
                            • godhunter74
                              @Substring
                              Si ca marche comme cela a été démontré faudrait l'inclure dans la distribution non ?
                                @godhunter74 oui oui oui 🙂
