    How To Regenerate A Specific ROM Folder?
    Emulator Arcade/PC/Console
    regenerate specific rom
    16496
    • tdelios
      tdelios last edited by tdelios
      Hi All..
      I accidentally deleted a rom sub-folder and it's contents by mistake. Specifically the 'colecovision' sub-folder in my 4.1 version Recalbox.
      Is there a hidden feature/function that I can run that will re-generate all or specific rom folders (and their files) so that I don't have to re-install the entire Recalbox from scratch again?
        voljega Banned @tdelios last edited by
        @tdelios you just have to recreate the folder nothing more
        • gmgman
          gmgman last edited by gmgman
          doesn't recalbox automatically create the folder if it is missing when you start it anyways? for me it's been like that if I recall correctly.
          edit: I see you're talking about recreating the deleted roms. well, you could use a file recovery tool on your PC and scan your SD Card/USB stick/HD, but I recommend to keep backups of your recalbox roms ony your PC, that you can simply copy back to your recalbox anytime, once you f**k things up. that's what I do.
          tdelios 1 Reply Last reply Reply Quote 0
            Substring @tdelios last edited by
            @tdelios the automatic par depends on many things ... Regarding a rom folder : it's supposed to be recreated
            • tdelios
              tdelios @gmgman last edited by
              @gmgman @voljega @Substring
              I tried rebooting the 4.1 a couple of times and still no 'colecovision' sub-folder under the rom folder is not generated.
              I manually created the 'colecovision' folder, rebooted but the 3 common system files that normally appear in each rom folder (_lisezmoi , _readme, gamelist) are not generated in my manually created 'colecovision' folder.
              I dumped all my .COL rom games into the 'colecovision' folder, rebooted and no colecovision displayed on the screen and the 3 system files are still not generated.
              Does anybody have the 3 default files (_lisezmoi , _readme, gamelist) from their 'colecovision' folder from a clean 4.1 installation?
              I don't want to go through the whole installation all over again.
                Substring @tdelios last edited by Substring
                @tdelios i made the test myself and it does regenerate. Are you running the latest unstable ?
                • tdelios
                  tdelios @Substring last edited by
                  @Substring yes.. I ran the update just to be sure..
                  Also, to confirm, the 'colecovision' sub-folder should be located under:
                  recalbox\share\roms\
                  I have 45 sub-folders under 'rom' , one of which I manually created the 'colecovision'.. If I remove that manually created folder, the only sub-folders that start with the letter "C" is 'cavestory'.
                  am I missing something?
                    @tdelios wait wait wait which pi are you running ? Are you sure /recalbox/share_init/roms/colecovision exists ?
                    tdelios 2 Replies Last reply Reply Quote 0
                    • tdelios
                      @Substring
                      Running Raspberry Pi version 3 .
                      don't have a 'share_init' folder.. just a 'share' folder as you can see from one of my attached screen shots: http://www3.zippyshare.com/v/N8K5dK2x/file.html
                      The second screen shot shows a 'colecovision' folder only because I put it there due to Recalbox not generating the folder (and any files within it).
                      http://www3.zippyshare.com/v/ydcJAjZc/file.html
                      • tdelios
                        tdelios @Substring last edited by tdelios
                        @Substring
                        I upgraded around 2 months ago from whatever the current version release was at that time to the 4.1 unstable version and then from the 4.1 unstable. Then recently, it asked me again to update to the latest version of 4.1.. I'm guessing there was at least one release in the 4.1 version since its conception.
                          @tdelios you're not showing me /recalbox/share_init/roms. You can't rezch that folder from network, you need ssh
                          • tdelios
                            @Substring
                            how do I do that with winscp and the terminal window?
                            not too familiar with ssh
                              paradadf Staff @tdelios last edited by paradadf
                              @tdelios just log in with winscp and navigate to recalbox/share_init/roms
                              • tdelios
                                tdelios @paradadf last edited by
                                @paradadf
                                I tried to do that using terminal, but it gives me an error that no such file or directory when I try to "cd share_init" folder
                                here is a screen shot when I run the 'ls' command to show you what I see on the screen: http://www102.zippyshare.com/v/214FNZjH/file.html
                                  @tdelios just ls -la /recalbox/share_init/roms
                                  • tdelios
                                    @Substring @paradadf
                                    recalbox's response:
                                    /boot$ ls -la /recalbox/share_init/roms
                                    total 184
                                    drwxr-xr-x 46 root root 4096 Feb 20 04:58 .
                                    drwxr-xr-x 12 root root 4096 Feb 8 18:36 ..
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 amstradcpc
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 atari2600
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 atari7800
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 atarist
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 cavestory
                                    drwxr-xr-x 3 root root 4096 Jan 1 1970 fba
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 fba_libretro
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 fds
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 gamegear
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 gb
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 gba
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 gbc
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 gw
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 lutro
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 lynx
                                    drwxr-xr-x 4 root root 4096 Jan 1 1970 mame
                                    drwxr-xr-x 4 root root 4096 Jan 1 1970 mastersystem
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 megadrive
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 moonlight
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 msx
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 msx1
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 msx2
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 n64
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 neogeo
                                    drwxr-xr-x 8 root root 4096 Jan 1 1970 nes
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 ngp
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 ngpc
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 o2em
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 pcengine
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 pcenginecd
                                    drwxr-xr-x 3 root root 4096 Jan 1 1970 prboom
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 psx
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 scummvm
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 sega32x
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 segacd
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 sg1000
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 snes
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 supergrafx
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 vectrex
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 virtualboy
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 wswan
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 wswanc
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 zx81
                                    drwxr-xr-x 2 root root 4096 Jan 1 1970 zxspectrum
                                      No colecovision ... So of course the folder can't be recreated !
                                      So i'd say you're either running a pi for which colecovision is.not compiled, either you removed the colecovision from the share_init folder.
                                      So once again : which pi are you running ?
                                      • tdelios
                                        I'm running Raspberry Pi version 3 ..
                                        I did not remove the 'colecovision' from the share_init folder as you can see I am not that articulate to do so.. I simply connect to my windows pc to the \roms folder that is available to me.
                                        As I mentioned before.. the 'colecovision' sub-folder was in the recalbox\share\roms\ folder once during the initial upgrade to 4.1.. but once I deleted it, it never came back.
                                        So it must be a bug.. not sure if it can be producable, but it is..
                                        either way, how can I get my 'colecovision' folder back with all the findings presented to you so far?
                                          @tdelios gotta check few things before I tell you how to proceed. Are you running a 4.1 img or an upgrade from 4.0 ?
                                          • tdelios
                                            @Substring upgrade from a 4.0
