    Removing All Games Causes Recalbox Not To Load
    Emulator Arcade/PC/Console
    removing causes recalbox
    • tdelios
      tdelios last edited by
      fresh install of 4.0.1 from GitHub.. updated to 4.0.2 when prompted.
      after reboot, I deleted all the rom games that came with the installation which in the past I have done many times.
      Rebooted the system and Recalbox doesn't load anymore, but can be connected on the backend via network.
      In the past, I was able to delete all the roms and the main screen not display anything. Now with the latest version, it doesn't load at all other than a black screen with the 4.0.2 on the bottom left of the screen.
      Once I loaded my roms into the appropriate folders and performed a hard reboot, recalbox came up fine.
        Substring @tdelios last edited by
        @tdelios why would ES start if there are no roms ? 😉
        tdelios 1 Reply Last reply Reply Quote 0
        • tdelios
          tdelios @Substring last edited by
          @Substring It did before prior to the 4.0 release.. just an observation as I thought I broke something by deleting out of the box rom files that came with the installation.. ;0
            @tdelios it creates the folder. But if the folder exists, it won't readd stuff inside
