    Unsolved Analog light OFF on playstation 2 controller
    GamePad/GPIO/USB encoder
    analog light playstation
    3694
    • torra87
      torra87 last edited by torra87
      Hi,
      I couldn't find the answer for this in the forum.
      I use an adapter to connect Playstation 2 controllers to recalbox. They work great, but the analog light, when opening and closing a game, always turns off.
      Does anybody know how to set the analog option always to ON. Or at least to turn it ON at the beggining of recalbox and then keep it ON until I shut it down.
      Thanks!
        Substring @torra87 last edited by
        @torra87 doh 😮 no idea ... Does it happen with every emulator, or just with libretro ones ?
        torra87 1 Reply Last reply Reply Quote 0
        • torra87
          torra87 @Substring last edited by
          @Substring i will test it with every system i have installed and come back 🙂
          thanks for the reply!
            @torra87 try N64, which is not a libretro emulator 😉 as well as scummvm moonlight, pifba (= fba2x) and many more on recalbox 4.1
            Btw you didn't mention which recalbox version you're running
            • torra87
              @Substring I started using recalbox from version 4 beta 2, and now i use 4.0.2.
              In all versions between it works the same way.
                @torra87 mmmhhhh ... would SDL be guilty here ? i don't think so ... I honnestly don't have any clue for now.
