    Solved Scraping using Universal XML Scraper fails
    scraping universal xml scraper fails
    • duskel
      duskel last edited by
      Hi guys,
      Facing some issues scraping using Universal XML Scraper (latest one 64 bits).
      At the end the images have been downloaded, the folder is created, but when I reboot it, nothing has been changed on my recalbox.
      I tried using auto-conf and choosing the options manually (for both methods I first killed the emulationstation).
      Any idea?
      Recalbox: 4.0.2
      Emulator: MAME
      Thank you very much
        paradadf Staff last edited by
        Are you 100% sure ES was killed? That's usually the reason for the behaviour you described.
        • duskel
          What I do is to connect via ssh as root and execute the following command:
          /etc/init.d/S31emulationstation stop
          As result I get black screen on my TV.
          I realized that is possible to do similar process in my computer (replacing recalbox folders by pc folders), but then I will need to move the downloaded images / gamelist manually, where exactly I need to place these files to execute this manual process successfully?
          Thanks!
            You copy everything into their respective roms/<systemname> folder. But again... ES must be properly shuted down (exactly as you are currently doing it).
            I hope you are using Windows, right?
            • duskel
              You were right, the problem was related to the ES, I tried again and worked. Thank you!
