    How to emulate X68K in Recalbox
    Emulator Arcade/PC/Console
    emulate x68k recalbox
    11
    70
    43100
      voljega Banned @acris last edited by voljega
      @acris huh ? i'm always happy to be thanked but why in that case ? 😄
      btw scanlines aren't used by the X68k emulator at least in 'Retro' config is it normal ?
        acris @voljega last edited by
        your upvote for my message 😄
        @voljega said in How to emulate X68K in Recalbox:
        I dont know , @rochaddicted any idea ?
          rockaddicted @acris last edited by
          @acris don't know maybe a typo.
            https://gitlab.com/recalbox/recalbox/blob/master/board/recalbox/fsoverlay/recalbox/share_init/system/configs/shadersets/retro.cfg#L51
            should be ok
              Hello
              What is the sequence to launch Genocide 2 ?
              Solution
              Genocide 2 (1991)(Zoom)(Disk 1 of 4)(System).dim
              Genocide 2 (1991)(Zoom)(Disk 2 of 4)(Data 1).dim
              Genocide 2 (1991)(Zoom)(Disk 3 of 4)(Data 2 ).dim
              Genocide 2 (1991)(Zoom)(Disk 4 of 4)(Data 3).dim
              renamed
              Genocide 2 (1991)(Zoom)(Disk 2 of 4)(Data A).dim
              Genocide 2 (1991)(Zoom)(Disk 3 of 4)(Data B).dim
              Genocide 2 (1991)(Zoom)(Disk 4 of 4)(Data C).dim
              FDD0 -> SYSTEM
              FDD1 -> Data A-> game start
              And remplace Data A To Data B
                @azvarel
                I think file hdf doesn't work on raspberry but I Think in recalbox x86_x64 may be
                because hdf file contains autoexec.bat or command.x for windows computer.
                @rtype
                pourquoi le format hdf ne fonctionne pas sur raspberry ? est ce un bug ?
                azvarel 1 Reply Last reply Reply Quote 1
                • azvarel
                  azvarel @acris last edited by
                  @acris I believe it is more emulator bug, I have xbox classic emulator that works perfectly hdf files.
                  Zodian Theme | #SNESProject
                    @azvarel
                    i read theses lines :
                    @rtype writed : be sure your hdf is in SASI format, SCSI one are not supported with this core. Also be sure (hit F12) that you don"t have some fdd set , if yes unset same and reset using the gui.
                    you can use diskexplorer to open it and see if they are Human68k HDD or SCSI. http://www.gamesx.com/wiki/doku.php?id=x68000:x680004
                    source : https://forums.libretro.com/t/px68k-libretro/10113/165
                    • azvarel
                      azvarel last edited by
                      Disk Explorer
                      I have read and reread the page, I already moved on diskexplorer, I can edit files inside the hdf, but I can not see if it is SCSI or HDD
                      @rtype we need your help
                      • chris256
                        chris256 @acris last edited by
                        @acris said in How to emulate X68K in Recalbox:
                        you need to create playlist file with name :
                        Akumajou Dracula (1993)(Konami).m3u
                        with inside 2 lines :
                        Akumajou Dracula (1993)(Konami)(Disk 1 of 2).dim
                        Akumajou Dracula (1993)(Konami)(Disk 2 of 2).dim
                        Hi ! I did this but I've got a black screen after launching the game and nothing happens. When I launch the menu, I see that the first disk is on FDD0 and the second one is on FDD1 (which I think is correct).
                        Before doing this and launching the first disk, I had a message in Japanese to choose : 1. X68000 2.(something else) 3.(something else)
                        When I chose 1, nothing happened (same for 2 or 3). I thought that was due to the missing second disk and that is why I tried the m3u thing. Now I don't even get the message.
                        Someone managed to make Akumajou work ? Thanks for your help !
                          @azvarel
                          I don't know too, may be when human HDD selected ?
                          I tried in xm6 emulator on my computer and few game worked with SASI but Akumajou Dracula (1993)(Konami).hdf didn't.
                          Edit :
                          Launch Akumajou Dracula (1993)(Konami).hdf with xm6 it's ok
                          tape with keyboard :
                          dir
                          cd drac
                          adra
                          I will try soon on raspberry
                          edit : on rpi2, required keyboard and you need to use dos command line.
                          @chris256
                          your game works with dim format only ?
                          Akumajou Dracula only 2 files.
                          can you post your m3u file and name file dim like me ?
                            @azvarel
                            I tired few hdf games and it's launch but a little long to load on my raspberry 2.
                            I wll try when my rpi3 will come back
                            8893db3872bbf347038701db253de9d5 *Akumajou Dracula (1993)(Konami).hdf
                            5c9ac688e157f7a97993b2511b59610f *Jotei Senki 4 Heroines Forever (1995)(Linner System).hdf
                            73dd7c5cc3b6a545f2657a20fc04dc1a *Super Street Fighter II (1994)(Capcom).hdf
                              Hello
                              /!\ Attention pour les jeux hdf assurez vous que FDD0 ET FDD1 soient vides .
                              Pour cela, lancer n importe quel jeu dim, puis aller dans le menu px68k(L2) puis dans FFD0 FFD1 choisir eject puis resortir du menu(l2) et sortir de retoarch (hotkey+start)
                              J'ai quelques jeux en format hdf contenant un dossier Games qui incluent différents jeux dans ce fichier.
                              Pour naviguer , la présence d'un clavier est obligatoire. La navigation à la manette N'est PAS possible.
                              */!\ Attention le chargement peut être long pour ce format hdf /!*
                              Vous pouvez créer ce type de support hdf pour le multidisc en suivant ce tutoriel :
                              https://www.youtube.com/watch?v=BXNh3sG65Xo&t=1082s
                              I have some games in hdf format Content in a file.
                              To navigate, the presence of a keyboard required
                              navigation on the controller is impossible
                              To make theses hdf file , look this tutorial https://www.youtube.com/watch?v=BXNh3sG65Xo&t=1082s
                              How to launch :
                              Open GAMES Folder :
                              text alternatif
                              Choose a game (enter keyboard)
                              text alternatif
                              Choose !Start.bat or !NoIntroStart.bat
                              text alternatif
                              Launch the game 😄
                              text alternatif
                              • kelv
                                kelv @acris last edited by
                                @acris Hello I tried Chourensha 68k but it seems sound does not work fine and the screen resolution is bigger than my 42 inches screen.
                                I tried to change the ratio to squarepixel but I couldn't fit the screen :(.
                                Any help pls 🙂 If sharp x68000 emulation is not ok far pls let me know also for not investing my time on it.
                                Raspberry Pi model: RPi 3b+
                                Recalbox build : 7.0.1 DragonBlaze
                                Hardware: MicroSD UHS 128 GB up to 80 MB, Class 10 and 2.5 A Power Supply.
                                Overclocked: 1485 MHZ
                                Controller(s): Wired Xbox 360 PAD (working perfectly on any other game/emulator).
                                  @kelv
                                  I will try tomorrow morning this game.
                                    @kelv
                                    The only soluce is enable : pixel perfect mode in emulationstation menu > game options.
                                    kelv 1 Reply Last reply Reply Quote 0
                                    • kelv
                                      @acris thx 🙂 And the sound, was it working fine for you?
                                        Zut i forgot to check sound.
                                        I retried tomorrow morning
                                        @kelv what rom use you for this game ?
                                        I use
                                        Chourensha 68K v1.01 (1995)(Famibe No Yosshin).dim
                                        on rpi3 no overlocking with usb key.
                                        @kelv
                                        I finally could test tonight.
                                        The sound goes up and down at times but it's not boring
                                        • Unpinned by  Zing Zing
