    Wifi working but still "NOT CONECTED"
    wifi still conected
    16403
    • cagiraudo
      cagiraudo last edited by
      Hi,
      I am new with recalbox, first at all let me congratulate the entire team for the great work you are doing.
      I fresh installed recalbox a few days ago, bug still having problem with the internet connection.
      WiFi is working, i CAN connect via network, i CAN connect via ssh, i CAN get the web mannager, i CAN use the scrapper, but i still get the "NO CONECTED" message.
      When i turn on recalbox i get the message that a new version is avaible, but i can't update becouse it say i need internet connection.
      I did research a lot and tried the solution of changing the ping website to archive.recalbox.com like you describe here: https://forum.recalbox.com/topic/5039/can-t-connect/41
      but still doesn't work. I checked the logs and now it tries to ping archive.recalbox.com but doesn't get response.
      I tried to ping any page via ssh or via the recalbox with F4 but i don't get any answer. The strange thing is that internet IS working, because i can use the scrapper.
      Here is some additional info:
      Raspberry Pi 3
      Recalbox 4.0.1
      Pepe 1 Reply Last reply Reply Quote 0
      • Pepe
        Pepe @cagiraudo last edited by
        @cagiraudo Have you modified the configuration to have static ip?
        cagiraudo 1 Reply Last reply Reply Quote 0
        • cagiraudo
          cagiraudo @Pepe last edited by
          @Pepe mmm, no, i don't have static ip. I mean, i set a static internal ip for the raspberry in my dhcp router configuration, but my ISP doesn't have a static ip.
          Should i change something in the configuration??
          I setted only the wifi ssid and password
          • Pepe
            Pepe @cagiraudo last edited by Pepe
            @cagiraudo in a ssh session, what is the output of cat /etc/resolv.conf?
            • cagiraudo
              @Pepe said in Wifi working but still "NOT CONECTED":
              nameserver 200.49.130.52 # wlan0
              nameserver 200.42.4.207 # wlan0
              • Pepe
                @cagiraudo Seems to be caused by DNS config. As u can check in network tools sites like this, the name server configured in your /etc/resolv.conf are not solving names. This is output of nslookup for google.com through dns configured on your recalbox:
                ... here is the nslookup result for www.google.com from server 200.49.130.52, querytype=ANY :
                ;; connection timed out; no servers could be reached
                ... here is the nslookup result for www.google.com from server 200.42.4.207, querytype=ANY :
                Try this to change dns config and solve the issue:
                1. https://github.com/recalbox/recalbox-os/wiki/Make-a-partition-writable-(EN)
                2. In Recalbox Wiki:
                  In order to get name resolution working, you will have to create a file names /etc/resolv.conf. By default, this files points to an auto-generated file located at /tmp/resolv.conf, so in order to do it once and for all, run the following commands:
                  rm /etc/resolv.conf
                  nano /etc/resolv.conf
                  Enter the following lines, which corresponds to DNS servers of the
                  OpenDNS project:
                  nameserver 208.67.222.222
                  nameserver 208.67.220.220
                  Save the file.
                  Now reload the settings with : ifdown eth0 && ifup eth0
                  THESE EDITS WILL BE OVERWRITTEN WITH EACH NEW UPDATE - You will have to repeat these tasks after each update.
                cagiraudo Substring 2 Replies Last reply Reply Quote 1
                • cagiraudo
                  i did what you said (at least i think i did) but it's still not working
                  • Pepe
                    @cagiraudo in a ssh session, what is the output of cat /etc/resolv.conf now?
                    If the content of the file is the same as before then the changes have not been saved. Do it again and pay attention to any posible errors that appear when you save. Otherwise in the last command of wiki instruction, the one u blockquoted, change eth0 by wlan0 or even better restart your recalbox.
                      Substring @Pepe last edited by
                      @Pepe nice and complete answer 🙂 congratz !
                      • cagiraudo
                        cagiraudo @Pepe last edited by cagiraudo
                        @Pepe
                        Indeed, thanks for your time and complete answers
                        I tried with ifdown wlan0 && ifup wlan0. Even restarting the raspberry, but still says "NOT CONNECTED"
                        • cagiraudo
                          cagiraudo @cagiraudo last edited by
                          @cagiraudo
                          Do you want me to paste some log?
                          • Pepe
                            Pepe last edited by
                            @Substring Thanks! 😄
                            @cagiraudo Try ping google.com in shh, Is there an answer?, if so, try to undo what u mentioned here:
                            I think this solution don't work now i think is a old tip for a temporary issue.
                            If there is no answer from google to previous ping, i think i give up, something else fails on your system in addition to the DNS resolution but I can not think what.
                            • cagiraudo
                              @Pepe
                              No, no response when i ping google.com. Maybe there is something strange with my network, i will keep trying.
                              Thanks anyway
                              • cagiraudo
                                there is something strange, i found out i can't ping with any device connected in my network, i can browse internet without problem, but anytime i try to ping some site i don't get answers, i tried with notebook, cellphone, recalbox, etc.
                                I know this is beyond recalbox, but do you have any idea what could be happening??
                                Thanks
                                • Pepe
                                  @cagiraudo Speculation: something related to ICMP protocol at router / firewall or even ISP level.
                                  • cagiraudo
                                    Just an upgrade, my ISP was blocking my ICMP packets.
                                    I solved that issue and now the recalbox connects to internet without any problem 😄
                                    Thank you @Pepe for the help
                                      Substring @cagiraudo last edited by
                                      @cagiraudo that was a very nasty network issue 😕
                                      • Pepe
                                        Pepe last edited by
                                        Well, the important thing is that it has been solved and nobody has fallen in the way. 😄
                                          @Pepe and mostly that Recalbox is not the problem hahaha 😄
