    PSX games doesn't load
    4882
    • neo-1986
      neo-1986 last edited by
      I have the same issue. I got a 32GB SD Card, everything works perfect. Now I bought a 128GB Samsung SD Card, everything works perfect, too, except the psx emulator. game seems to load but returns to frontend after 5-7sec.
      i installed recalbox on the new sd card. Then, I copied the working folders roms, saves, bios from the 32gb SD Card to my computer and copied them back to the 128gb share folder.
      This way, I did not have to scrape games again. And as I said, everything except psx works perfect, even mame or neogeo which are quite difficult to run because you need the correct mame/rom version.
      The whole copying and copying back to the sd card took about 10-12 hours. So I don`t want to format my sd card again (by the way, it came with exfat, i formatted it to fat32).
      Has someone an idea what the cause of the problem could be?
      the bios, saves, roms folders of the two sd cards are identical and both run 4.0.1 version of recalbox, even the background music and controllers are the same 😉
      hope to hear from you soon. kind regards Neo
        Hello
        split topic , please don't up old topic.
        you need to upgrade in recalbox 4.0.2 (last version)
        samsung it's not recommanded.
        • neo-1986
          neo-1986 last edited by neo-1986
          Sorry I got 4.02 . I looked up compatibility list and my Samsung card was listed. Everything except psx works so I am not sure if it is really the fault of the Samsung
            try to delete your gamelist.xml (backup before)
            check in /recalbox/share/bios if you have bios.
            • RustyMG
              RustyMG last edited by
              On a side issue I'm also using a Samsung 128gb card with absolutely no problems.
              Whatever the issue is, it isn't the card.
              Sinclair ZX Spectrum 48k "dead flesh" keyboard, Commodore 64, Amiga A500, Amiga A1200, CD32, PC Engine, PS1, PS2, PSP, Nintendo DS, Dreamcast, Wii, XBox 360, Xbox One-X, Pi2, Pi3, Pi4 owner, ARRM contributor ( http://jujuvincebros.fr/wiki/arrm/doku.php ).
              • Tobaunta
                Tobaunta last edited by
                I had the same problem but it got fixed when I disabled "Auto Save/Load" in the game settings.
