    BestArcade4Recalbox questions
    • gmgman
      gmgman last edited by
      I have some questions regarding your spreadsheet for BestArcade4Recalbox
      https://docs.google.com/spreadsheets/d/1F5tBguhRxpj1AQcnDWF6AVSx4av_Gm3cDQedQB7IECk/edit#gid=423376617
      1. how often is this spreadheet being updated?
      2. Who updates this spreadsheet?
      3. Is it possible to add a new Column in the tabels and add a Code for the "working/not working status", so that people can sort the lists by working Status (e.g. Code 1 for working (now green background) to Code 4 for not working)?
      There is no way to sort the list by Status atm, I would like to copy the Column Rom Name for roms that only work 100% (green Background), paste it in a txt, make a batch script that reads from the txt file line by line, compares the name to my mame Rom set and if it finds the corrsponding .zip file moves it to a subfolder which then has all tested to work fine roms inside, so I can put these onto my recalbox.
      voljega paradadf 2 Replies Last reply Reply Quote 0
        voljega Banned @gmgman last edited by voljega
        @gmgman
        1. Whenever there's a new version of mame or fba_libreto or a new Pi version so until 4.1or a Pi4 is released no update
        2. Me
        3. Yes it should be possible I wanted to do that but I have been lazy :op but you can copy the file and maybe try to do some filtering based on the background color to orderthe rows and then add another column for your purposes
          paradadf Staff @gmgman last edited by
          @gmgman check the first and second post here:
          https://forum.recalbox.com/topic/4740/recalbox-compatibility-lists
          The batch already exists (aka. fastsorter).
          • gmgman
            I see, thanks for the heads up!
