    [4.1-Unstable] Problem loading roms from a NAS after the update from 4.0
    nas mount shared folders
    • tonyloco
      tonyloco Translator last edited by
      Hi there,
      after the update, Recalbox seems not seeing the roms on the NAS. FYI I followed this guide:
      https://github.com/recalbox/recalbox-os/wiki/Load-your-roms-from-a-network-shared-folder-(EN)
      But "mount -a" seems not working at the boot. Only after logging on Recalbox with the Terminal, typing manually "mount -a" and refreshing the roms list, it works.
      Do you have any tips for this problem?
      Thank you
      Distracted and hyperactive gamer at Distrattivo
      Pepe 1 Reply Last reply Reply Quote 0
      • Pepe
        Pepe @tonyloco last edited by
        As well says the how to that you paste link in their last lines,
        Warning :
        If you update Recalbox, a new S31emulationstation will be created. So >restart from : Now edit S31emulationstation
        So after each update you will have to re-modify
        etc/init.d/S31emulationstation to add mount -a again and change the start order to start emulationstation after network.
        tonyloco 1 Reply Last reply Reply Quote 0
        • tonyloco
          tonyloco Translator @Pepe last edited by
          @Pepe
          I've just done it, but nothing happens, and that's the reason why I asked for an advice.
          • Pepe
            @tonyloco I'm not a programmer, but, in this image I think the mount -a statement is misplaced. It is not within the code block of the case statement. Probably the solution is to move the mount -a statement 9 spaces to the right to leave it inside the code block, at the same position as the rest of the code block in the start) case.
            • tonyloco
              @Pepe It worked before the update.
              The indentation is only for a stylistic matter.
              101.4k
