    Unsolved copy pi 3 sd card to pi zero w sd card?
    copy card zero
    3315
    • Emrah Yiğit
      Emrah Yiğit last edited by
      Hi there,
      is it possible to copy everything from the raspberry pi 3 sd card (including roms, downloaded images, game information, ...) to another and then use it in a raspberry pi zero w ? i do not want to copy/scrape all the stuff again on my PI Zero W, so I wonder if i simply can copy the sd card and put it in the ZERO W ... Hope to here from you soon. thanks
        Hello
        no it's not possible to clone RPI3 SDCard to RPI0 W. It's not the same system.
        RPI0W is not compatible with recalbox 4.0.x neither recalbox 4.1
        but with configuration manually : https://forum.recalbox.com/topic/6853/raspberry-pi-zero-w-rien-s-affiche/25?page=2
        after install, you transfert roms, scrap, downloaded images, and saves state but attention
        • Emrah Yiğit
          thank you but my french is bad so the link doesnt't help. so can i install recalbox on the ZERO W or is it not possible? thank you for your help
            No, it's not compatible
            • Emrah Yiğit
              then what do you mean by configuration manually? can i install recalbox manually somehow?
                you need to add manually few files in recalbox 4.1 it's explain in link posted.
                Uses google translate otherwise you have to wait for it to be official
