    Multiple Xbox Wireless Controller with one receiver
    GamePad/GPIO/USB encoder
    xbox 360 contro
    4301
    • Dante
      Dante last edited by Dante
      Hi,
      I make it quick. Is it possible to use multiple Xbox 360 controller with one Xbox 360 receiver on the recalbox? At the moment, I have one original ps3 controller and one CSL controller working, but I want to switch to two Xbox 360 controllers, because I have two of the laying around here.
      So if I buy a receiver, can I use both or more controllers, just with one receiver? That would be awesome!
      Edit: I am using the latest stable version of recalbox.
      • azvarel
        azvarel last edited by
        max 4 controllers
        Zodian Theme | #SNESProject
        Dante 1 Reply Last reply Reply Quote 1
        • Dante
          Dante @azvarel last edited by
          @azvarel do I have configure something or is it plug n play? Thank you for the answer!
          • azvarel
            In Manager you can set the amount of xbox 360 controls or recalbox.conf. Remembering maximum of 4.
            • kdawg
              kdawg last edited by
              Hey,
              Just wanted to tack onto this question. Similar issue, but with PS3 controller.
              I have a RPi3 with Recalbox and am trying to use multiple controllers. Currently I only have one logitech playstation 3 controller that has a USB dongle. Can I use multiple controllers to one bluetooth dongle? I do not have any open USB ports for more dongles....
              Thanks,
                paradadf Staff @kdawg last edited by
                @kdawg if your logitech controller came with one usb receiver, the controller is probably just a wireless controller and not a bluetooth controller. If so, it is mandatory to use it for that one controller to work. You can always attach a usb hub to expand the usb ports but usually hubs with external power supply work better.
                • MarcDK
                  MarcDK last edited by
                  Can you plug in two Xbox usb connectors and connect 8 controllers this way?
                  https://marc.tv
