    Problem with Raspberry pi 3
    3357
    • LuccasMB
      LuccasMB last edited by
      I have a problem, I have one raspberry pi3 and one sandisk micro sd ultra card 64gb. I copy the files to the sdcard 64 gb previously formatted in FAT32, with guiformat or fat32format I tried both. With Recalbox 4.0.1 I don't have problem installing but when I try to open system settings, the recalbox crash in one black screen. If I try to install other version as 4.0.0 or older, it is recognized and the installation starts, however, when it reaches 100%, the following error message appears: " recalbox rPI-3 error filesystems mounting ". My sd card is new, I tried to use him with Usb adapter and SD adapter and I still have the same problem. Someone could help me?
        Hello @LuccasMB
        wrong format.
        if you are windows users please look this video :
        https://www.youtube.com/watch?v=hl59A3FTK-U
        • LuccasMB
          Hi @acris I saw this video now and tried again two times as the video says.With the version 4.0.1 I still have the same problem, when I try to open system settings the recalbox crash in one black screen. I tried also the version 4.0.0-beta5 and when the instalation reaches 100%, the following error message appears again: " recalbox rPI-3 error filesystems mounting ".
            I need more information hardware, screen etc...¨
            https://forum.recalbox.com/topic/3647/before-posting
            you need microsd compatible with recalbox : scandisk class 10
            https://github.com/recalbox/recalbox-os/wiki/Compatibility-(EN)
            • LuccasMB
              LuccasMB last edited by LuccasMB
              This post is deleted!
              • LuccasMB
                Raspberry Pi model: Raspberry pi 3 model B v1.2
                Recalbox version (build) : 4.0.0 and 4.0.1
                Hardware (Micro SD, Power Supply, etc.): Micro Sd SanDisk Ultra 64GB UHS-1 Class 10 (new) , Power supply 5v and 2.2A.
                Controller(s):Keyboard sharkoon - skiller.
                This link says that my micro sd is compatible. I don't know what to do more, I have just bought this micro sd and I don't want believe that my micro sd have problem but I can't see what can be.
                • LuccasMB
                  Someone could help me? Retropie works fine but recalbox no.
                    Your problem is your microsd. You need to format in FAT32 as PRIMARY or try an another.
                    You power supply must be 5V 2.5A minimum.
                    • careisaac
                      careisaac last edited by
                      The problem is with Card size and power supply. Raspberry Pi 3 SD card maximum officially “compatible” SD card size is 32 GD. Above that the card formats to exFAT 32 which would require you to convert it to FAT32 through sdxc_formatting. Also, the power supply must be minimum 5V 2.5A.
                      100.8k
