    Solved System exits from emulestation only pressing START
    Mandos/GPIO/Codificador USB
    exits emulestation pressing start
    5219
    • j0taele
      j0taele last edited by
      Hello to all,
      I'm using the last version of recalbox with rpi 3 and arcade pads.
      I have 8 buttons so I configured A, B, X, Y, L, R, START, (SELECT, HOTKEY in the last button). With this configuration the system exits from games only pressing start button. However seems how hotkey button is not working.
      regards and thank you
        Hello
        Hotkey must be select button.
        Do you try to remapp controllers in emulationstation menu.
        • j0taele
          Hello acris, Thanks for your quick reply.
          I have tried to remapp a lot of times with the same result. However, if I don't map one button (the button I lke for select and hotkey) and map other button (e.g which was previously L) for select and hotkey. Then works and exit emulestation with hotkey + Start. But is not the button map I like.
          I do not understand why this is happening. I have read the manual and forums but I have not found anything. Is it possible to modify it manually in a configuration file?
          Thanks for support 馃檪
          NeeeeB 1 Reply Last reply Reply Quote 0
          • NeeeeB
            NeeeeB @j0taele last edited by
            @j0taele
            Are you sure your button (the one you want to assign to Select and Hotkey) works ?
            Because if select/hotkey works with another button, it looks like your button is not working properly.
            Did you try to assign this button to another command ? (like assigning it to A and then try if it works...)
            Or maybe you should check your GPIO inputs ? are you sure you used the correct pin for your button ? (they are really near to each other). I had a similar problem where one of my buttons didn't work and it appeared i had not used the correct pin on the GPIO.
            Vieux geek ^^
            j0taele 1 Reply Last reply Reply Quote 0
              paradadf Staff last edited by
              It is not very clever to assign the HK to buttons like A, B, X, Y etc. as these combos have functions and you'll be triggering those every time you press that single button. This is specially noticeable and annoyin when you assign the HK to the Start button, as you will be quiting the game by pressing Start.
              As acris said, use Select. Personally I prefer L3, but if you don't have a full size controller (and even with it) Select will work fine.
              • j0taele
                j0taele @NeeeeB last edited by
                @neb said in System exits from emulestation only pressing START:
                @j0taele
                Hello @neb I have connected the buttons to a USB controller, I don't use the GPIO pins.
                When I configure the buttons I press the button and the system detect it so it seems to works. But tomorrow I try changing with another button. Anyway, don't you seem strange that I can exits only pressing one button (start)? I don't understand.
                • j0taele
                  Perdonad, no me hab铆a dado cuenta que estaba en el foro espa帽ol XD
                  Vuelvo a plantear mi problema:
                  Estoy usando la 煤ltima versi贸n de recalbox en una Raspberry Pi 3 con mandos de arcade conectados a controladoras USB y estas a su vez, conectadas a las Raspberry.
                  Tengo 8 botones, los cuales los configuro como A, B, X, Y, L, R, START, SELECT y HOTKEY (estos dos 煤ltimosjuntos en el mismo bot贸n). Con esta configuraci贸n, cuando entro en un juego y le doy al bot贸n que tengo asignado como START el sistema se sale y vuelve al men煤 de Emule Station. Sin embargo, si no configuro este bot贸n, perdiendo uno y el SELECT / HOTKEY lo asigno a otro bot贸n, entonces si funciona,
                  驴Alguien sabe por qu茅 me puede estar pasando esto?
                  Saludos!!!
                    paradadf Staff @j0taele last edited by
                    @j0taele ya te respondi en ingles. Solo se puede salir presionndo unicamente Start si asignas la Hotkey tambien al Start.
                    (Excluyendo la opcion en la que la placa mande se帽ales erroneas cuando presionas algun boton).
                    • j0taele
                      @paradadf finalmente era por la controladora USB, efectivamente parece que mandaba se帽ales err贸neas. He soldado el cableado de otra manera y ahora ya funciona sin problemas. Muchas gracias cierro el hilo como solucionado
                      101.4k
                      Copyright 漏 2021 recalbox.com
