    Raspbian+OSMC+Lakka+Recalbox on Vilros (Recalbox not starting)
    MediaCenter & Dualboot
    vilros recalbox starting
    4636
    • crattystrat
      crattystrat last edited by
      I have Recalbox, Raspbian, OSMC, and Lakka on a Vilros Raspberry Pi 3 model B and Recalbox is not starting. This is the Pi: http://www.vilros.com/vilros-raspberry-pi-3-ultimate-starter-kit-clear-case-32gb-sd-card-edition.html Thanks for your help.
        Substring @crattystrat last edited by
        @crattystrat what does "recalbox is not starting" ?
        crattystrat 1 Reply Last reply Reply Quote 0
        • crattystrat
          crattystrat @Substring last edited by
          @Substring Nothing happens when I try to boot into it. It's just a blank screen.
            @crattystrat how did you install it ?
            • crattystrat
              @Substring I installed it using NOOBS, because it's what the card came with and I wanted to multiboot.
                @crattystrat netinstall through noobs ?i hope you had enough space on your sd ?
                • crattystrat
                  @Substring It was 32GB and I did have enough space...
                    @crattystrat you don't even get the recalbox logo ? nothing ?
                    • crattystrat
                      @Substring Yeah, absolutely nothing, except for a little sound, and everything was plugged in.
                        @crattystrat do you remember the installation sequence of all this ?
                        • crattystrat
                          @Substring I just checked the boxes for the OSes I wanted, then clicked install. It was connected to the internet then.
