    Overclocking does not improve the Performance
    overclocking does improve performance
    • Eomer
      Eomer last edited by
      Hey Guys,
      i overclocked my Raspberry Pi3 (latest Recalbox version) by putting the following lines in the boot.config
      arm_freq=1400
      over_voltage=4
      sdram_freq=575
      sdram_schmoo=0x02000020
      over_voltage_sdram_p=6
      over_voltage_sdram_i=4
      over_voltage_sdram_c=4
      core_freq=500
      v3d_freq=500
      h264_freq=333
      gpu_mem=256
      force_turbo=1
      dtparam=sd_overclock=100
      I removed the preset gpu_mem from the boot.config.
      Note: I have passive AND active cooling and i'm aware of the fact that force_turbo=1 will void my warranty.
      However, i did this to have a few more FPS while playing PSX games or in order to play PSX games with a higher resolution. I did not check the actual FPS (is there a tool for that)?
      I can't see any subjective improvement while playing the games. Does anyone have an idea why that is?
      Best regards
      Eomer
      xtreemsurf Pho3nX 2 Replies Last reply Reply Quote 0
      • xtreemsurf
        xtreemsurf @Eomer last edited by
        @Eomer
        I recently added a fan to my Pi and thinking of overclocking. Did you ever end up seeing a difference or did overclocking do nothing for you? Thanks!
        • Pho3nX
          Pho3nX @Eomer last edited by
          @Eomer
          What do you mean by "boot.config" ???
          You must edit your config.txt, not a other file (and put permissions because this file is RO)
          For me i just edit config.txt with this values (from: https://www.youtube.com/watch?v=3B3AnuOmRcQ) and it's great !
          arm_freq=1400
          over_voltage=4
          gpu_freq=450
          DAM 1 Reply Last reply Reply Quote 0
          • DAM
            DAM @Pho3nX last edited by DAM
            @Pho3nX , this settings works on RPI2 ?
            @Pho3nX said in Overclocking does not improve the Performance:
            @Eomer
            arm_freq=1400
            over_voltage=4
            gpu_freq=450
            Pho3nX 1 Reply Last reply Reply Quote 0
            • Pho3nX
              Pho3nX @DAM last edited by
              @DAM
              No it's only for PI3, method is the same on PI2 but not the same values
